Tip & How-To about Plumbing
HOW TO CHANGE A BALLCOCK ON COMMODE
HOW TO REPLACE A BALLCOCK ON A WATER CLOSET, COMMODE: FIRST SHUT WATER OFF TO COMMODE. THER WILL BE A WATER SHUTOFF VALVE BETWEEN THE FLOOR AND THE COMMODE ON THE WATER LINE TO YOUR BALLCOCK, TURN WATER OFF, FLUSH COMODE SO YOU CAN CLEAR MOST ALL OF THE WATER OUT OF IT. THEN UNCREW THE NUT FOR THE WATER SUPPLY, THEN UNSREW THE NUT FOR THE BALLCOCK ITSELF, OPEN THE TOP OF THE COMMODE, YOU WILL SEE A FLAPPER ON THE BALLCOCK, REMOVE IT, THEN TAKE THE BALLCOCK OUT, SOME HAVE A ROD AND FLOAT SOME DO NOT, EITHER WAY IF IT DOES WHEN YOU PUT THE BALLCOCK BACK IN THE SAME WAY THE OLD ONE CAME OUT MAKE SURE YOU HAVE THE GASKET ON WHEN YOU STICK THE END OF THE BALLCOCK BACK, TIGHTEN THE NUT, THEN MAKE SURE YOUR WASHER IS IN THE NUT ON THE WATER LINE AND RE CIONNECT WATER LINE, YOU CAN ADUST FLOAT VALVE BY BENDING THE ROD DOWN TO THE AMOUNT OF WATER YOU WILL WANT CONNECT FLAPPER BACK, TO THE NEW BALLCOCK, IF THE BALLCOCK DOES NOT HAVE A FLOAT, YOU CAN ADJUST PER INSTRUCTION, SO AFTER ALL THIS IS DONE AND TUBE IS CONNECTED FROM BALLCOCK TO THE TOP OF IT WITH CLIP, TO DIRECT YOUR FILL WATER, TURN YOUR WATER ON AND ADJUST SOME MORE IF NEED BE, UNTILL YOUR CORRECT AMOUNT OF WATER IS LIKE YOU WANT IT...THIS IS REALLY EASY COMPARED TO PAYING A PLUMBER FOR THIS JOB, AND IT HAS TO BE DONE QUITE OFTEN, LARRY VEAL MASTER PLUMBER TEXAS
Plumbing Logo
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off completely, need check valve or fill valve or flow valve or seat valve, found some numbers, tank 1167.10 and k3400TB, lid 8919 13 K4546 date 5-13-75
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
Villeroy & Boch flush tank doesnt get water
Hi pervana....
You have an obstruction in your ballcock/inlet valve or the ballcock/inlet valve is malfunctioning and is need of replacement.
Try to move the float up and down inside of the bowl, this may loosen the valve and allow water to enter the tank.
If this does not solve your problem then you will need to replace the ballcock/inlet valve.
Free Answer...Please take time to rate me
May 16, 2011 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
shutting off water valve problems
Some shutoff valves are pretty marginal to start with, then they corrode. They can easily break if you put too much force on the handle. You are wise to be cautious. You will have to turn of the main water supply and then replace the toilet shutoff valve. You might be able to replace the shutoff valve yourself, depending on your skills and depending on how the shutoff valve is connected to pipe coming out of the wall or floor. But keep in mind that if you get in over your head you will have no water in the house until you get that new shutoff valve in place.
If you can describe what kind of pipe that shutoff valve is connected to I can help you understand if you should tackle it yourself.
Jun 29, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
Overflow - Cold water shutoff not working?
Sounds like the cold water valve is faulty. You can try to remove it and clean the inside if it's clogged or replace it completely.
Jun 25, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
425 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
