Tip & How-To about Washing Machines
Odor from your towels or clothes washer?
With newer higher efficiency washing machines flooding the market today, new issues arise. One annoyance is odor of mildew on towels or coming from the front load or even top load machines.
With a little maintenance and care this trouble can be eliminated and avoided in the future.
If you currently have the odor locate one of the following products
- Affresh
- Smelly Washer
Run the hottest cycle without clothes and the product you chose. If the washer is especially bad you may need to run a second clean out using another dose.
After the washer is clean be sure you only use the recommended detergent for your product. HE detergents are required for most all front loading machines and a lot of new top loading machines too. This is very important, because if the wrong type is used it can cause build up in hidden areas that will cause odors as well as performance issues and even premature failures of components.
Do not use any additives that are not recommended for your machine, check with the manufacturer or owners guides for specifics.
Leave the lid or door open at least partially when not in use, this will move air through the unit to help keep odors away.
Use the Affresh or similar product once a month in the machine to keep anything from building up where you can't see.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
Wont Stop Filling http://www.fixya.com/TipsAndTricks/preview.aspx?thid=4621172
Control Locked http://www.fixya.com/support/r4624473-control_locked
Washing Machines Logo
How do I clean the front seal most efficiently? There is an odor and other junk that really needs cleaning.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Fowl Smell
If the smell is a mildew type odor this is common with the newer energy efficient machines. To remove the odor I would suggest using a product called Affresh or Smelly washer. These used on a monthly basis will help eliminate and keep it from coming back. If it is practical to leave the lid open when not in use that will also help. The products I talked about are available at Target, Lowes and grocery stores near the laundry detergent.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Laundry
Interesting article explaining the problem associated with Front Loader Washing Machines and new products to combat the mold/fungus build up inside them.. Check it out....------------------------------------------------------------
Consumers who own front-loading washing machines should use only about one-quarter of the recommended amount of high-efficiency, or HE, low-sudsing detergent. Standard, non-HE detergents in front-loaders are too sudsy.
Why don't top-loading machines have this problem? Less efficient top-loaders that use more water typically flush out excess suds, soil, detergent and fabric softener.
Class-action lawsuits against manufacturers such as LG, Whirlpool and
Maytag have been filed, alleging mold and mildew problems in front-loading washers.
Some suits have been settled while others are pending, affecting hundreds of thousands of consumers, said Rob Shelquist, a partner at the Lockridge Grindal Nauen firm in Minneapolis.
According to Whirlpool, the low water use and airtight seals on HE front-loaders create the potential for odor-causing mold and mildew. Whirlpool has its own anti-odor product, Affresh, which sells for $7 for three treatments. SmellyWasher is more expensive than Affresh initially ($16 for 24 treatments), but Flynn's product lasts a year.
SmellyWasher can be used as a preventive monthly or less often if smaller amounts of detergent are used. Affresh is also used monthly, but a $7 packet of three tablets lasts only three months. Flynn's product will remove musty odors from towels or clothing, which Affresh does not claim to do.
Getting rid of problem
To eliminate odors, Smellywasher users should put a capful of Flynn's product in the detergent dispenser, select the hottest water temperature and the extra-large load to fill the empty washer with the largest amount of water. Let the water agitation start and then stop the washer and allow the solution to soak for two to four hours. Repeat as necessary and allow to soak overnight if needed.
Flynn said that the product works best in hot water. Consumers might want to run the faucet closest to the washing machine until the water is hot before starting the process or turn up their water heater temperature until the load is finished. (Remember to turn the temp back down to avoid scalding.) Flynn offers a money-back guarantee. Stubborn cases of mold and mildew might require five to seven treatments.
Susie Thymian is such a believer that she now sells SmellyWasher in her own store, McGinnis Appliance in Morris, Minn. Thymian had blamed the musty smell from her towels on her teenagers, who often leave wet towels in a pile in their bedrooms. Her kids' solution to the stink was to use more towels. Thymian's answer was to use more bleach in the laundry, but nothing got rid of the mystery mold odor until she found Flynn's product.
Only a few of Flynn's customers are from
Minnesota so far. Most come from regions with higher humidity. Sharon Turner, who lives in steamy San Antonio, said SmellyWasher worked after several cycles. "I was ready to throw out my plush towels and my front washer. It saved my sanity."
Link to this article..http://www.chicagotribune.com/business/chi-smelly-washer_chomes_0912sep12,0,7369054.story
Sep 14, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
2,078 people viewed this tip
Top Washing Machines Experts
