Tip & How-To about HP vp6320 Multimedia Projector
Replace HP VP6321 Projector Lamp
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
HP vp6320 Multimedia Projector Logo
dull image on projector
This is an old projector which was released in May 2005. Projector image degrades over time as the lamp dims, and other internal factors affect brightness. The original rating is 1600 lumens which is not bright compared to a modern projector.
You can check to status which may give you lamp information by pressing ENTER on remote or projector and going to HELP.
You may find that replacing the lamp helps, however older lamps are expensive and could replace the whole projector with new one of higher specification, complete with 3 year warranty if you spend double as much. A new lamp will not restore a projector to its new state either. Here's a link to the lamp (for the UK), it's over £200 + VAT + delivery, and that's not even for a genuien HP lamp
http://www.every-projector-lamp.co.uk/projector-lamps.php?&brand=HEWLETT+PACKARD&model=VP6310
As I say, you can get projectors with a better spec for as little as £372 + vat + delivery. This one is similar to yours, in that it is a 4x3 business projector. It has an XGA resolution. (Yours is VGA). It is 2000 lumen brightness and it has a 3 year warranty.
http://www.ivojo.co.uk/projector-spec.php?pid=Samsung_SP-L201
Hope this helps...
Feb 21, 2011 | HP VP6310 Multimedia Projector
HP VP6310 projector problem
Usually it is the color wheel sensor. Know problem. I can fix it.
Jan 19, 2009 | HP vp6320 Multimedia Projector
HP vp6320 projector
You need to replace the color wheel sensor. I can fix it.
Dec 01, 2008 | HP vp6320 Multimedia Projector
2,727 people viewed this tip
Seeker5211
Seeker5211
