Tip & How-To about Computers & Internet
LOST PASSWORD OF YOUR COMPUTER ?
Don't worry if you have lost password of your log in in computer..
here i give you very simple idea.
just start your PC..
before booting process press F10 key.. or F8 key and then start Windows in
SAFE MODE.. ( this option will be there to choose as you press key mentioned). that's it. you can now access anything.. cheers.. :D
Computers & Internet Logo
Forgot Windows xp password
Don't worry - if you forgot Windows XP password, this article will show you several methods you can used to find a Windows XP password.
Mar 27, 2011 | IBM Lenovo ThinkPad X40 Notebook
i for get my password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
or
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
hope it helps.
don
Feb 20, 2011 | Computers & Internet
how to reset password on my compaq computer!
Start pc in "Safe Mode With Command Prompt" When windows starts, type your log in name in the dos window with an asterisk. For example ( john * ) but with out the (). It will prompt for a new password. Reboot and Bam your in. If you cant remember a log in name exactly as it is, type in ( net users ) and hit enter.
Jun 13, 2010 | Compaq Digital PC 3100 PC Desktop
forgot password logging in
you will require windows cd to reset or remove the password,first boot with cd and you get option to press any key to boot with cd ,press any key now windows will start copying files ,dont worry we are not reinstalling windows so keep up the installation process till you get the screen which says installing devices and windows time will be approx. 39 minutes to complete installation
quickly press Shift key+F10 this combination will stop windows installation and new window will pop that gives you option to reset and remove password.
Now do as you like and remove windows cd ,
It is the best possible solution you may find in all of cyberspace ,no harm to computer is done ,i hope you will be happy to use this technique and help others as well.
Kindly rate this solution Thanks And Regards
Feb 23, 2010 | Dell Inspiron 1000 Notebook
182 people viewed this tip
David Payne
David Payne
