Tip & How-To about Computers & Internet
HOW TO CHANGE ACER CD/DVD DRIVE IN MINUTES
You will need a small posi screw driver,(tiny phillips)
take the battery off,
disconnect the ac power pack too.
on the bottom of the base is a single screw at the end of the cd/dvd drive,remove it
now it should slide free from the body,
if it doesnt the take off the power cover on the front,
this exposes the keyboard and ribbon,2 small screws
sometimes its easier to remove the keyboard,
allowing you to give some leverage to slide the old drive forward
Should take about 5 - 10 minutes max,
all done , Yeah, now fit the new one
Replace the covers and power ,time to test,finished
Computers & Internet Logo
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
how do I remove and replace the cmos battery A135 toshiba
If you have idea about it ......but this link can help you ...in this.. check it.....http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Please rate and vote if you found this one helpful
Thanks
Sanjay Kumar
Apr 25, 2011 | Computers & Internet
how do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
How do I remove the CD/DVD hardware drive from Aspire 5520 laptop ..i want to replace it with a new one...where do i start first?
It will slide out once you unscrew one set screw. Flip over the Laptop and you will see several small screws. Gauge which one by figuring about 5.5 inches long from the edge of the front of the CD Rom and normally it is the middle or off just one inch either way.
If you try several screws it wont disrupt anything... just put them back of course.
Press firm while unscrewing...don't chance stripping and have the right size screw driver :)
Jan 24, 2010 | Acer Aspire 5520-5156 Laptop
how do I open my HPw 1907 Monitor
Start by removing the base. There are 3 screws. First pull the base plate off. Then remove 2 screws. Next remove the little rubber insert in the center of the base bracket. You will need a long phillips to get to the 3rd screw. Slide out the base bracket. Flip the panel over and stare at the lcd with the buttons side on the top. Grab a small flat head screw driver. Look at an angle in each of the corners between the inner black lcd trim and the silver outside trim. There is a ****. Shove the flathead in there and pry outward toward the silver trim while lifting on the black inner trim vertically. The trick is to flex the black trim toward the silver and then pull up. There are 6 plastic snaps on the top and bottom, and 4 snaps on the left and right. If you've taken laptop screens apart, you'll feel the similarity.
Once you pry the black trim off the front. Disconnect the LCD Menu button assembly and power button. Then flip over the LCD and lift off the back shell. Looking at the back, remove the 2 connectors for the speakers. Use a small flathead to pry the 4 Inverter power connectors. These 4 connectors have a clip on them and are usually hard to pull out using the wire. Once thoses 6 connectors are removed, remove the 2 phillips screws holding the AC power plug to the case. Also remove the 4 3/16 posts for the VGA and DVI ports. Next remove 4 screws, 2 screws from each side of the LCD assembly. Hold the panel face down with the aluminum tape in the bottom left. Lift the shield and guide the 6 wires through the cage. While opening, look inside and disconnect the flat ribbon cable as soon as you can. Put the LCD to the side. Remove 2 screws from the Video processing board, and 5 screws from the power supply. Note: 1 of the 5 screws is longer. Rotate/slide the power PCB away from the cage to clear the speaker and AC plug, Then rotate towards the Video board. Disconnect 1 plug. The OTHER plug is SOLDERED and must be disconnected from the video processing board.
Aug 05, 2009 | HP w1907 LCD Monitor
129 people viewed this tip
David Payne
David Payne
