Tip & How-To about Computers & Internet
How to access your home PC files remotely
There are a couple of ways of doing this. Here are a couple of my favourites. All of these require you keep your computer on.
1. Opera Unite
If you install the freeware browser Opera, then create an account with them, you can start Opera Unite, an online service for accessing files and services from anywhere. After you have added the File Sharing application from the Unite sidebar, you can configure the application. Choose to add a share location and choose your main hard drive (generally C:). Then, change your password and make sure that you set your Opera Unite account to private and check that File Sharing is password-protected. Then simply navigate to the URL that Opera provides (generally username.operaunite.com), enter your username and password and then you'll have full access to your files. Note that you will need to keep Opera running on your Computer
2. FTP server. *Only recommended for advanced users
By running a FTP server software like FileZilla on your home computer, you can create a far more powerful file sharing experience. Now, first up, you should go to DynDNS.com, sign up for a free account and then create a Dynamic DNS host. Next, download and install the DynDNS Updater and run on your computer. Now, to access the files that you have configured with your FTP server software, simply use your DynDNS hostname that you created in the sign-in process into Windows Explorer or Internet Explorer (or any browser) with the ftp:// prefix instead of http://. However, if your computer is on a home network behind a router, you will need to configure that also. Set up a port forward (generally Port 20,21, and 23) to the computer running the FTP server. The other advantage to this is that by finding out the server's local IP address (open Run, then type cmd, then type ipconfig, and write down the IP address shown) you can also access the files from the server within your network, simplifying the file access process greatly.
3. Orb 2.0
This is one of the slickest and smoothest methods. Simply download and install the Orb desktop client from Orb.com (also create an account and enter your details into the Orb client), then add any folders you want to share. Then, allow some time for it to index your content. Now, from outside your network, log in to Orb.com with the account you created and click on the Applications button at the top of screen. If you want the music, videos, photos or documents you specified in the setup process, choose the appropriate application, or choose File Sharing to access all of your files at once. Simply navigate the folders as if it was your local computer and you will be able to use them flawlessly. You can even access other physical drives like your CD drive online.
4. TeamViewer
This is a brilliant VNC replacement application. Simply create an account, then install the client on your computer. Also, enter your account details into the client (click the button at the bottom right of screen) and write down your 12-digit ID and password. From here, you have several options remotely. I recommend that you should link up your account first. Navigate to login.teamviewer.com and login, then add a client using the ID and password from your computer. Now, whenever you login to your account, you wont have to remember your ID/password. You can install the client on another computer and connect with your account directly or login to teamviewer.com and use the Java-based applet to connect and use your computer as if you were in front of it.
These should work well when accessing your files.
Computers & Internet Logo
what is error code 60
this error code is on what? tattooed on your forearm? miraculously appear on your tv during finals in your favourite sport or soap opera?
telepathy do not work, we do not know,
you need to give us a chance to answer, what manufacturer, what model, what is the problem what did you try to solve it and if computer related - what operating system
Feb 13, 2015 | Office Equipment & Supplies
Hi.. I cant open opera mini after I connected my 2690 to a desktop via cable.. pliz help1
hello friend,
First of all,you should download opera mini 5 from the internet.if you have Nokia 2690 with data cable then you can easily access internet on your computer.you can make your Nokia 2690 as a modem.how should you do this? i am giving you some tips as follows.please keep it up.
1) Open http://www.google.com
2) Type Opera mini for Nokia 2690 on Google search bar
3) Click on http://www.megamobilecontent.com/software/Nokia-2690/Opera-Mini-i16804/
4) Click on Opera Mini (5.1.21214) Download
After downloaded Opera Mini.jar file (size is 266kb) on your computer,
5) Open opera mini.jar file
6) if you have installed Nokia PC Suite then message appear:- Do you want to install the application to the phone?
7) Click on right tick button that is YES.
8) After installation, message comes,Installation complete.
9)Open your Nokia 2690
10) Click on Applications
11) Click on Collection
12) There at last you will find opera mini icon.
but before running it.i suggest you restart your mobile at once.now you can surf internet through opera mini 5 regularly basis.
Good Luck.
Thanks for using FixYa
Jan 12, 2011 | Nokia 2690 Cell Phone
How can I block ads in opera. Is there a way to do it Like AdBlock in Firefox Mozilla? Any system of tweaking Opera 10.x so that it can block annoying ads??
Unfortunately there is no add-on to just install, but here is a solution which is pretty close:
1. Find the folder storing the .ini files for your Opera browser. On Windows this folder is usually C:\Program Files\Opera\defaults. Depending on your OS just locate your Opera main folder and navigate to defaults.
2. Save the urifilter.ini file from this address: http://www.technobeta.com/download/urlfilter.ini in the folder
This is all! Opera will now block the main ads present on the Internet.
! the defaults folder gets overwritten at each update, so make sure you repeat the process when you install a new Opera version
!! The urifilter.ini file at http://www.technobeta.com/download/urlfilter.ini gets updated quite often so you might want to repeat the process from time to time to make sure you keep all those annoying ads away ---------- This is the best solution which Opera can offer, though it's not by far as efficient as the most common Firefox addons..
Hope this helps, wbwTeam
Mar 29, 2010 | Opera Software Browser
Storing my favourites on my PC
You can make a new folder in my computer and click and drag your favorites there so you can keep them there. This should work.
Nov 10, 2008 | Garmin StreetPilot c310 GPS Receiver
133 people viewed this tip
David Payne
David Payne
