Tip & How-To about Cooktops
Product recalls
You can learn about most product recalls, well in advance by going to www.usa.gov and selecting consumer guides. You'll be surprised at the number of recalls that you were never aware of.
Cooktops Logo
I have a cvg4380 and I need to replace the igniters , how do you remove and replace the igniters
The link below shows the different parts for that unit. There is a button under the items that says watch video.
http://www.appliancepartspros.com/search.aspx?model=cvg4380
Feb 18, 2017 | Jenn-Air Cooktops
I need to know the specs for whirlpool rs630pxk
Do you need the size of the RS630PXK range? The range is 30" wide, 31 7/8" high and 22 3/4" deep. The installation opening needs to be larger to allow for air circulation around the range. It needs 120V AC power. The specifications for the size and the installation space size is given in the installation guide. Whirlpool has the guide on their product support page. The direct link to the installation guide is http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%20311433.pdf . All of the documentation can be found by searching on the model number starting here: http://www.whirlpool.com/manuals/ .
I hope this helps.
Sep 30, 2015 | Whirlpool Stove / Oven / Range Cooktop -...
The left rear stove element went on High and would not turn off by controls, why? There was an F550 code that came earlier with the oven?
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
USER MANUAL FOR SAMSUNG CERAMIC HOB C61R2AEE
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU . The support tab is on the right. The manual for the cooking hob can be accessed from the Need More Downloads link below the Download button.
I hope this helps.
Jul 06, 2012 | Cooktops
Can a GE profile black 4 burner with down draft gas cook top be converted to propane gas? How?
Hi and welcome to FixYa, I am Kelly
Everything I am reading says this unit comes with an LPG conversion Kit. It may have been removed by the detailer / retailer that you purchased it from (when ever that was.)
The 0.0354 orfices are supposed to be in the front of the inside of the cooktop and are labeled LP.
It is a matter of removing the 4 Natural Gas orifices and installing the LP orfices and then adjusting the air-flow of the grill burner Air Shutters as shown in the manual on page 32.
The center nut has to be removed from the top of the internal gas regulator and the mini post / plunger inverted and then the nut is reinstalled.
Just note that any conversions are supposed to performed by a qualified gas technician as stated by the WARNING in the manual on page 30.
The manual is here:
http://www.hammerwall.com/tempmanuals/L0603449.pdf
The step by step instructions are in the product user guide on page 30
or you can go to this link and click on info and guides:
http://www.ajmadison.com/cgi-bin/ajmadison/JGP990.html
then download the use and care guide.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | GE Profile Nonstick Griddle for Downdraft...
1,415 people viewed this tip
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
