Tip & How-To about Computers & Internet
How to delete system32
Press start, run, type in cmd, press enter, type del/windows, enter , and then y, enter , youre done :)
Computers & Internet Logo
what is the process for cleaning autorun.inf
Method One
  • Open command line (CMD) and write the following:
del /a:rhs [driveletter]:autorun.inf
  • Simply Replace [driveletter] with your drive. If the virus is on the D drive the commad will be
del /a:rhs D:autorun.inf
  • Restart the computer & Done.
Second Method
Genreally when you refresh the windows explorer view a bounded virus process recreates this file. This file is attached to many events of windows explorer including OPEN, REFRESH, etc.
You must close opened explorer windows.
1. Open up a command prompt (i.e. cmd.exe) >> to load it go to Run, type cmd, enter.
2. Now to remove virus's attributes (in order to delete it type following line by line and execute them pressing enter.
F:
F:attrib -s -r -h *.*
If there are any malicious EXE files those are now visible so if unnecessary delete them too.
F:del autorun.inf
3. After finishing above, quickly remove the pendrive as soon as posible (just after executing del command).
4. Now your pen is without virus activation config. file. Now you can safely delete unnecessary EXE files on it.
Method Third
  • Download Flash_Disinfector.exe from here and save it to your desktop.
  • Double-click Flash_Disinfector.exe to run it and follow any prompts that may appear.
  • The utility may ask you to insert your flash drive and/or other removable drives including your mobile phone.
  • Please do so and allow the utility to clean up those drives as well.
  • Wait until it has finished scanning and then exit the program.
  • Reboot your computer when done.
By this way you can remove
Jan 28, 2011 | Computers & Internet
how to delete files in cmd
1.go to start 2.click run and type cmd 3.locate the file in your drives... ex. C:, D: or any removable drives. and type dir to view the file in the specific drive or folder. 4. and type del and the name of the file . and press enter .
Oct 29, 2010 | Microsoft Windows XP Professional
Error : em8tqm.cmd
may be it cause virus praveen
go to start button and click run
and type cmd
then type
cd\ and press enter
then type
attrib -r space -h space -s space autorun.inf then enter
ex: 1. attrib -r -h -s autorun.inf enter
2. del autorun,inf enter
after that go to d: and press enter
Apr 08, 2009 | Microsoft Windows XP Professional for PC
pc problem
Goto Start-> Run and type cmd and press enter, You will get a dos command window.
Next type 'cd\' and press enter it brongs you to c:\ root.
1.Now type attrib -h -s -a -r autorun<and then press TAB key to get full filename(it will be either .ini or .inf> and then press enter.
2.Now type del autorun<TAB key> and press enter.
Now type 'd:' and press enter.
Now follow steps 1. and 2. again on D drive and restart the computer or you can restart the Explorer prosses in process manager. Now the problem should be solved
Oct 28, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
204 people viewed this tip
David Payne
David Payne
