Tip & How-To about Computers & Internet
How to fix iphone error 1013
The best thing to do is if your are getting an error while restoring the iphone/ipod touch-
Try another cpu - if you have a friend or family member try their cpu or apple cpu -
You ipod cannot be restore from your cpu !
if you get the same error number on 2 different computers then your ipod need to be taken to the apple store or serviced
Happy Hunting
Computers & Internet Logo
getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
My Ipod Touch 8G is locked i need help get back on it my friends thought it would be funny to change it on me because they are mad at me and now i cant get back on it can you help me?
That's a sad thing! If your friends won't tell you the code, then all you can do is to restore your iPod touch. To do that, follow my instruction here, but I must tell you that restoring your iPod will remove all its contents including the jailbreak (if your device is jailbroken).
Good luck.
For more iPod touch / iPhone tips, click here.
Mar 05, 2010 | Apple iPod touch
iphone Frozen in Boot Screen
hello again!
try to restore option first on your iphone.
step 1: Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. .
Step 2: Connect iPhone or iPod touch to your computer.
Step 3: In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
Step 4: Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
Step 5: Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
May 08, 2008 | Apple iPhone Smartphone
iPod Touch WiFi issue
  1. Tap Settings > Wi-Fi Networks, then pick the network.
  2. In the DHCP panel, select the Renew Lease button.
  1. Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. Apple recommends using the latest version of iTunes.
  2. Connect iPhone or iPod touch to your computer.
  3. In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
  4. Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
  5. Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
Dec 27, 2007 | Apple iPod touch
141 people viewed this tip
David Payne
David Payne
