Tip & How-To about Computers & Internet
How to install any software in windows7 even it is not compatible with it.
There is a simple trick.Click on software's setup i.e .exe file click properties->compatibility and change it to Win XP SP3.Now save changes & install the software.It will perfectly work with win7.
Thanks!
Computers & Internet Logo
Print Master Gold 16 compatible with Windows 7?
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 03, 2010 | Broderbund Print Master Silver 16.0 for PC
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Driver
no new driver or update needed after installation of vista, copy your old driver cd on hard drive, click properties on setup(aam6000ug driver or ... ) file and select compatibility and change the mode to windows xp sp2, then enjoy your win vista
Apr 25, 2007 | ASUS AAM6000UG Modem
192 people viewed this tip
David Payne
David Payne
