Tip & How-To about Garden
Jumping your small engine.
Always ensure when jumping a small engine that your car engine is turned off.
Garden Logo
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
Engine does not turn. Car wont jump start
If your battery has a short it will not jump unless you clip the ground cable to the engine or something iron or steel. Positive on the battery negative on engine. Always do this when jumping because the car giving the jump could ruin their computer.
May 17, 2010 | 2000 Buick LeSabre
1997 Cirrus battery went dead. The car ran fine
These cars are known for having engine related electrical problems that can be difficult to track down. One dead sensor is sufficient to prevent start up .
It is possible that your problem had nothing to do with the jump start or battery replacement.
Without a full diagnosis anyone not able to test the vehicle will be guessing.
One thing I would do is to check your fuse panels for all engine related fuses such as fuel pump, ignition and fuel injection to ensure these fuses are sound.
Check all visible wiring carefully including your battery connections. Carefully disconnect and then re-connect the battery at both terminals.
Your best option is to have the car towed to a reputable repairer that is familiar with these cars so he can run a full check and isolate the problem.
Whether you have blown something in the course of jump starting the car is unknown.
In future, when jump starting these older vehicles always turn the headlights on and do not turn them off again whilst the vehicle is running until after the spare battery used for the jump start has been fully disconnected. Everything else should be off.
Dec 05, 2009 | 1997 Chrysler Cirrus
how to jump start it
To jump start any car, you will need to have either a portable jump starter (that look like the ones found here: http://www.autobarn.com.au/products/7/45/3022812/) or have jumper leads which look like alligator clips.
To use either option, attach one side of the jumper cables to to your battery, then attach the other end to another car battery (or in the case of the portable jump starter, it will be already connected with the unit).
Ensure the correct color cable is attached to the correct battery terminal (metal point on battery), i.e. red to red, black to black.
Caution: Car batteries have a high amperage and can lead to electrocution if you touch both metal points on the battery. Always be careful when doing so and if unsure, do not attempt to do so without assistance from a competent individual.
Oct 24, 2009 | 1990 Buick Riviera
engine won.t turn
hi can you turn engine over by hand [engine s not sezied ] and how did you test the battery and how did you test starter because if the engines not seized and you put a jump lead from your positive terminal off a good battery to a starters main terminal and it wont, turn over the starters faulty or there is no engine earth so connect the other jump lead from the negative battery teminal to the engine block and try again it will turn over if the starters good if the starter turns over with the jump leads check the small terminal on the starters wire is live when someone turns the ignition key if it is and the starter does not turn over then the soleniod on the starter is faulty if no live at small terminal then the ignition switch or starter relay are faulty best of luck yates2104546
Oct 14, 2008 | 1994 GMC Jimmy
146 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
