Tip & How-To about Cameras
How to take best pictures.
1. The best pictures can be taken with a tripod and using self timer or the remote control of the camera.
2. Some people think that the best picture can be taken with suddenly pressing the shutter. In reality it is not true. So the best pictures can only be taken with two steps. First, pressing half way and without not shaking the camera continuing on pressing the shutter. At last the camera takes picture. But a good photographer does not know the moment of taking the picture. He/She only knows and concentrates on not shaking the camera.
3. Best pictures can only be taken with an artistic point of view. Best photographers place the subjects to the most estetic point and the best estetic position.
4. Best pictures can only be taken without using the flash.
5. Best pictures can only be taken at the Golden Hour time. Golden Hour is the time period, starting with the Sun rise and ends after an hour. Second Golden Hour starts before an hour of Sun Set and ends with the Sun Set.
6. Best pictures can only be taken by a best photographer so you can never see a best photographer's portrait as a best picture.
7. Best pictures can not be taken with a most expensive camera but can be taken by a best working amateur photographer.
8. Best pictures can not be taken by professionals but can be taken by the professional amateurs.
9. Best pictures can only be taken with the camera which has a greater sensor size.
10. Best pictures can only be taken with a natural view of the objects.
Cameras Logo
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
On the easyshare m575 what does the self timer/burst feature do?
Self-timer
(10-second delay) it will have a 10 on it
Time to get yourself into the picture. Place camera on a tripod or flat surface.
Self-timer
(2-second delay) it will have a 2 on it
Allows for a steady, auto-shutter release on a tripod.
Self-timer
(2 pictures) it has a 2X on it
Capture 2 shots (one picture taken after 10 seconds and another picture taken 8 seconds later).
First Burst
Flash forced off.it has like 2 folders in front of the camera
Camera takes up to 8 pictures (2 per second) while the Shutter button is held. The first 8 are saved. (Capture an expected event e.g., baseball swing)
Last Burst
Flash forced off. it has 2 folders behind the camera
Camera takes up to 30 pictures (2 per second up to 15 seconds) while the Shutter button is held. When the shutter button is released, only the last 8 pictures are saved. (Capture an event when the precise timing is uncertain e.g., a child blowing out birthday candles.)
Mar 03, 2011 | Kodak Cameras
How do you adjust a camera at night?
At nights you should careful at these points.
1. If you take pictures when the camera is on your hands, ISO number of the camera must be increased to higher numbers. This lets the light come in to the lens easily.
2. If it is possible, a tripod is highly recommended to use. If a tripod is used, at that time,the best picture can be taken.
3. Hand Shake resistance speciality of the camera must be used.
4. Flash must be used. But with no flash and using tripod will give you the best results. If there is an action in the frame flash must be used.
5. While using tripod the best pictures can only be taken with self-timer.
Mar 08, 2010 | Polaroid i733LP Digital Camera
using self timer on my digital camera
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
Self-timer icon appears at the bottom of the LCD:
10 seconds—A picture is taken after a 10-second
delay (so you have time to get into the scene).
2 seconds—A picture is taken after a 2-second
delay (for a steady, auto-shutter release on a
tripod).
2 shot—The first picture is taken after a 10-second
delay. A second picture is taken 8 seconds later.
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
312 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
