Tip & How-To about Televison & Video
How to troubleshoot a DLP TV.
When you turn your DLP television on and get nothing but a clicking sound you could have almost anything wrong with it.
First you should check the lamp. as this is the weak link in this technology. If your unit is 6 or more years old I would replace the lamp whether the light says to or not. Your manual should tell you how to find the lamp and replace it. Typically the lamp replacement is the least difficult problem to solve.
If you lost your manual you can get a new one for free from http://www.retrevo.com . They do not have all manuals but the ones they have are free.
For this repair I would recommend a service manual. You can purchase one from http://www.servicemanuals.net for about $16.00 USD and you can usually download it immediately.
If the lamp is blackened or smokey inside it probably needs replaced. If the lamp is not bad the next likely area would be the low voltage power supply section.
First, is the standby light blinking in some sort of pattern? If so, count the number of times it blinks between long pauses. If it is blinking in a patten, this is an error code, and can be helpful in diagnosing the problem. Depending on the manufacturer the blinking pattern will mean different things. Error code lists are available by googling "(manufacturer) tv error codes". Proceed from here based on the information provided by the error code list. There should also be an error code list in the service manual.
If your set has no blinking lights proceed by unplugging and looking at the mainboard for burned resistors or bulging electrolytic capacitors. Electrolytics look like little cans, with shiny ends and are generally black, grey or blue. They have a positive and negative lead so be careful when replacing to get the polarity correct. If they are bulging replace them. Also replace any bad resistors found. Of course looking for blown fuses goes without saying but these days you rarely find a blown glass protection fuse. At this point it would be a good idea to inspect all solder joints on all boards, but especially the Low Voltage section, and resolder anything which looks suspicious.
Finding no charred resistors or bulging caps, no bad fuses and after resoldering all suspicious connections, your unit still does not work, check all semis in the LV power supply (diodes and transistors). Replace any bad units found and check all associated resistors and replace as necessary.
If after all the above procedures are tried, and your unit still isn't working, you may have to replace an entire board. These days most boards are relatively inexpensive. The most likely board would be the LV power supply.
Any parts or boards needed can be ordered at http://www.encompass.com or http://www.shopjimmy.com .
Good luck with your troubleshooting and be careful while inside the set especially near the High Voltage second anode where it connects to the CRT.
Thanks for using FixYa.
hardrocko
Televison & Video Logo
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
blue screen no sound no picture what is wrong with it?
Could be as simple as on the wrong input as well!
Apr 25, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Our samsung DL-P5663W PROJECTION TV HAS BEEN MAKING A LOUD SOUND SOMETIMES WHEN WE TURN IT ON. What is wrong and how do we fix it?
Hello
Normally, DLP Tvs must turn on silently. If your DLP projection TV makes a loud sound [you haven't specified anything about the sound you hear from it, either from its speaker or from inside]; it should be checked and get retified soon, otherwise, there is a chance to get DLP module damaged. If it does happen, it means that your DLP TV is out, because, the cost of DLP will be very high. Get the fault retified as fast as you can. Never switch on your TV, till this fault has been rectifed. you haven't given here enough details of fault, and so, I can't send you a solution to you. OK.
Mar 22, 2011 | Samsung HL-P5663W 56" Rear Projection HDTV
Click the power button, and makes clicks like trying to turn on, but doesnt. and keeps clicking. Sometimes turns on, sometimes doesnt. Anything i can do?
sounds like the bulb warning indicator is telling the tv that the bulb needs to be replaced.
you may need to replace the bulb but for now go into the service menu and reset the bulb .
Dec 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
2,694 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
