Tip & How-To about Microwave Ovens
If youur microwave is not creating heat
Then its probably the magnatron they are a very exspensive item to replace so unless its a super expensive microwave best you send it to heaven ..
sonic boom electorincs australia
sonicboomelectorincs@hotmail.com
Microwave Ovens Logo
microwave will not heat food
Unless an expensive unit replacing the Magnatron and or Inverter that powers the unit will cost more than replacing the unit itself.
Nov 03, 2012 | Samsung SMH9187 Microwave Oven
OC, Over current
99% of the time you have over current with a Microwave, it is typically the Magnatron, then the HV transformer, as first suspect. If you plugged the unit directly into the wall outlet it would probably blow a fuse. The Magnatron is the large item that makes the Microwaves.
You are speaking of an Inverter so you probably have the Microwave in an RV. RV Microwaves are typically expensive because they fit in small places and it you may want to have it repaired.
E
Nov 22, 2011 | Microwave Ovens
microwave runs but does not heat
in 99 % of cases the problem is the magnatron it is a very expensive part and unless the microwave is well worth the money we normally write the units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
Dec 01, 2010 | GE Microwave Ovens
I have a whirlpool model MH7140XFQ and we got a guy to come and look at it and he said the Mag. tube and the circuit bars were broken. Which would be more expensive to change the broken things or just change the microwave
He is referring to the magnatron tube which is the heart of the microwave. Probably more expense than you would want to put in to it.I would recommend replacement unless it is a high end model. Hope this helps
Jul 24, 2009 | Whirlpool MH7155XM Microwave Oven
I think I broke my baby...
If it's dead, it's probably a blown fuse or maybe a blown thermalcouple fuse. a bad magnatron won't make the unit apear dead unless its blowing fuses.
Hope that helps..
Geno
Mar 24, 2008 | GE JES1142SF Microwave Oven
199 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
