Tip & How-To about Computers & Internet
Battery Charge at high temperatures and low
Nickel-metal-hydride is less forgiving than nickel-cadmium, if applied in high and low temperatures. Nickel-metal hydride may not be quick to load below 10 â° C (45 â° F) and can not be slow to load below 0 â° C (32 â° F). Some industrial chargers are designed to adjust the rate to the current temperatures. price sensitivity does not allow the processing temperature sensing charger consumers.
At higher temperatures, the charge acceptance of nickel-based BTP-58A1 batteries is drastically reduced. A HP 530 battery that provides up to 100% when applied at moderate temperature can only accept 70% if charged at 45 â° C (113 â° F) and 45% if charged at 60 â° C (140 â° F). This demonstrates the poor performance of some summer car charger.
Lead-acid is fairly tolerant to extreme temperatures, as we are familiar with our car batteries. Part of this tolerance is accredited to the slowness of the system lead-acid. Some brands Inspiron Mini 9 (all 8.9 series) battery can freeze and low loads, while others say the damage and provide reduced service and a short life.
To improve the performance of lead-acid battery to colder temperatures and avoid thermal runaway during periods of heat, the control voltage limit, at which the INSPIRON 9300 battery is charged, is important. Implementation of this measure can extend the battery life of up to 15%. General guidelines suggest a compensation of approximately 3 mV per cell per degree Celsius. The voltage regulation has a negative coefficient, meaning that the threshold voltage decreases with increasing temperature.
Heat kills DV2000 battery. The hotter the cells, the shorter the life. High temperatures can not always be avoided, especially during fast charging, but efforts must be made to keep this short time. While 45 â° C (113 â° F) is acceptable if kept short, at 50 â° C (122 â° F) and above, the battery starts to suffer. Note that the cells inside the packaging are always a few degrees warmer than the temperature of the body.
Computers & Internet Logo
How do I recharge the battery on a Polaroid t1455 Camera?
Depending on the battery formulation, you may want to apply the proper type charger or AC adapter. More specific data in battery type would be beneficial to further answer. As lithium ion, nickel metal hydride, nickel cadmium and lead acid type batteries are all so different it would require the proper charger selection for the battery .
Jan 15, 2015 | Polaroid t1455 Digital Camera
I charged the battery and now I receive the following message on the camera display "for use with compatable battery only" then the camera shuts down.
Make, model?
Some camera's have a setting in the menu, to swich them between, Alkaline, NiMh (Nickel Metal Hydride) and NiCad (Nickel Cadmium) batteries.
Cheers.
Oct 01, 2009 | Cameras
New batteries act flat in Olympus camera!
Do not use "ordinary" alkaline batteries. Try using rechargeable batteries like nickel cadmium or nickel metal hydride.
Mar 10, 2009 | Olympus Camedia D-435 Digital Camera
Batteries always low
If you're using regular alkaline batteries that?s fairly common. If you want longer life most people purchase rechargeable nickel-metal hydride batteries and a charger. Depending on the camera you?ll get 40 or more flash images out of a charging. I have two sets, one in the camera and one in the charger. Expect to pay about $5 to $10 for a set of four and around $10 or $20 for a charger, make sure its for nickel-metal hydride batteries and not the old style nickel-cadmium. Good luck and don?t forget to rate this post.
Mar 03, 2007 | Polaroid i832 Digital Camera
What is the difference between the available AA battery chemistries?
AA batteries are available in four basic varieties: Alkaline Nickel-Metal Hydride (NiMH) Nickel-Cadmium (NiCad) Photo Lithium (Li-FeS2) Alkaline and photo lithium are non-rechargeable, while NiMH and NiCad are rechargeable. Each has advantages and disadvantages. Non-Rechargeable vs. Rechargeable: Rechargeable batteries are desirable from an environmental standpoint because they are reusable. Self-discharge refers to the fact that batteries lose energy when unused and even when not in a camera or other device. Rechargeable batteries tend to have relatively high self-discharge rates, approximately 1-2% per day for nickel-based batteries. Non-rechargeable batteries generally have very long shelf lives and extremely slow self-discharge rates. This makes non-rechargeable batteries a better choice for infrequent usage. Non-rechargeable batteries are available fully charged in stores all over the world, which makes them a convenient choice for travelers or customers who have dead rechargeable batteries and no time to recharge. Photo Lithium Batteries (Li-FeS2) (non-rechargeable): Photo lithium batteries will yield the longest battery life of any AA battery, surpassing NiMH by 50-100% and surpassing alkaline by 100-500%, depending on the load. While they are more expensive than alkaline batteries, their additional energy capacity makes the cost the same or less per shot than alkaline batteries. Nickel-Metal Hydride Batteries (NiMH) (rechargeable): NiMH batteries are the lowest cost overall solution for users that take a lot of pictures (more than the equivalent of a roll of film per month) or use a lot of high-power features. The largest disadvantage to NiMH batteries is their fast self-discharge rate of 1-2% per day whether the batteries are in a camera or not. NOTE: NiMH batteries need to be completely charged and discharged a few times when new to achieve their full capacity. Rechargeable batteries will eventually fail. If you have been getting acceptable battery life and then see a decrease in life, either quickly or slowly over time, a worn-out battery may be the cause. Storing or charging the batteries in high temperature conditions will accelerate this potential failure. Alkaline Batteries (non-rechargeable): Although the cheapest and easiest to find, alkaline batteries yield the worst performance of all the chemistries in a digital camera. They lose capacity at high power drains and at low temperatures. Skiers and other winter outdoor enthusiasts may find them unsatisfactory. Alkaline batteries are frequently available in two types: High drain (ultra, titanium, maximum etc.) Regular The high drain versions are a premium product designed to operate better under heavy loads than the standard product. However, there is a trend of major brands to increase the performance of their standard battery to b
Aug 30, 2005 | HP Photosmart 120 Digital Camera
177 people viewed this tip
David Payne
David Payne
