Tip & How-To about Computers & Internet
Review Asus Eee PC 1101 HA
The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
Computers & Internet Logo
ASUS 1101HA HARD DISK LOCKEED NEED PASSWORD
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is availible) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Sep 23, 2012 | ASUS Eee PC 1000HE Netbook
asus eee pc top case cracked
If it still works then just put a piece of duct tape over the crack.
Jun 28, 2012 | ASUS Eee PC 1005 10 Inch Series 1101HA...
how to fit a keypad to asus eee pc 1005ha
Hello, Please follow the bellow link and you can solve
http://netbookitalia.it/asus-eee-pc-1008ha-guida-disassemblaggio-e-upgrade.html http://netbookitalia.it/asus-eee-pc-1101ha-smontaggio-componenti-hardware.html http://cegeekbook.blogspot.com/2009/12/asus-eee-pc-1005hab-tear-down.html http://cegeekbook.blogspot.com/2009/12/asus-1005hab-disassembly-tear-down.html
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
i'm having trouble opening my asus eee pc from hibernation mode
ok,
1- disconet the power supply
2- take the bat. off
3- now press the power button for a few seconds (20)
now put only the power suply and reboot
May 13, 2010 | ASUS 1101HA-MU1X-BK Netbook
163 people viewed this tip
David Payne
David Payne
