Tip & How-To about Computers & Internet
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
Computers & Internet Logo
i am using server 2003 as file server wchich is in workgroup and connected to the network. problem is arising when any system from the network wants to access the shared folder the user unable to access its showing error "network path was not found" but its pinging to the server please assist me how to solve this issue....
Try this:
go to start>run and type: \\ server ip address
for example, if its 192.168.10.20, type \\192.168.10.20
Navigate to that shared folder, right click on it and create shortcut.
If the previous step doesnt work, go to server, unshare that folder, restart and share it again. Try accessing it.
Hope this helps
Aug 11, 2010 | Microsoft Computers & Internet
how to I install a shared printer successful, to a acer laptop as well as a Dell desktop.
to install shared printer first you have install printer in a desktop or laptop. after that share the printer. for that go to printers and faxes ? right click share the printer. give a name to identify the printer. Go to other system open network places ?entire network open system which you installed printer > open printers folders and right click on printer name select connect. If you cannot access system from network places. type ip address of system (in which printer is installed) on where you want to install printer. ex: in run > type //192.168.0.25 and press enter and open printers folder and right click on printer and connect
Jul 13, 2010 | Acer Aspire One PC Notebook
network issue
Hello
This is an unusual error. Error Code 1236 - The network connection was aborted by the local system.
There is no single issue that causes this error code, so we need to verify all of the networking basics are covered and working.
1. Verify the IP address, Subnet Mask and Default Gateway are fully entered and / or populated by the DHCP server. Click START, then RUN, type in CMD then click the OK button. Type IPCONFIG /ALL - verify the three fields all have valid info for your network.
2. Verify you can see the local network - including other computers and network devices. This will rule out the possibliity that this computer cannot see any network devices and not just the shared folders
3. Log the user out and have another user that can access the shared folders log into this comptuer and try to access the shares. The user profile could be corrupted and preventing the user from accessing the shared folders. IF the new user cannot access the shared folders, then it is the PC / OS causing the issue. IF they can access the shared folders, backup the original user's data, delete their profile and have them log in again to create a new profile.
It is always recommended to upgrade Windows XP to Service Pack 3 - unless you have a very specific program that will not run on SP3.
May 04, 2010 | Microsoft Windows XP Professional SP2
HI , i have the problem with my Scan to PC to scan the File to my Server , i have runing the Active directory on my server , i have made an administratoor account with full access on my my share folder on Server , but Bizhub 350 cannot send the File to that Folder , please help me on this
this would be on a domain then
1 open the default domain controler security setting
2 local policies
3 under security setting for microsoft network server set: digitally sign communications from always to disable
so with digital sign on the server the scan jobs are not digitally signed and will be rejected by the server.
or you could set it up to scan ftp or email if you have either one of those type of servers in the buiding they cant be external servers
Oct 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
shared printing problem
Go to Control panel open printers and faxes delete the existing printer, re install it by clicking the add printer, browse the path to your boss machine, when you find the printer auto install it.
Dec 18, 2008 | HP Business Inkjet 1000 Printer
306 people viewed this tip
David Payne
David Payne
