Tip & How-To about Computers & Internet
SET YOUR MODEM'S MAX SPEED
  • Double click the Modem icon in the control panel. The 'Modem Options' window appears. Two tabs should appear, 'General' and 'Diagnostics'. Select the 'General' tab, then select 'Properties'. which opens and has a 'Maximum Speed' box about half way down.
  • Open the box and select 115,200, then 'OK'.
If you have a 56kb/s modem this setting won't hurt it, but a setting of 9600 could slow it down.
Computers & Internet Logo
my wireless laptop cannot detect wireless networks..
Try this,
* Click Start * Click Control Panel * Select Network and Internet Connections * The Network and Internet Connections window will appear: Select the Network Connections icon * The Network Connections window will appear: Double click on Local Area Connection * The Local Area Connection window will appear: Select the General tab and click, or highlight Internet Protocol and press Properties * The TCP/IP Properties window will appear: * Make sure that both the Obtain an IP Address Automatically and Obtain DNS Server Address Automatically are selected, or checked.
If this helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely Thiyaga
Aug 28, 2011 | Acer Aspire 5315 Notebook
i need help to create a new account in microsoft outlook for e-mail?
For Windows 7:
  • If Control Panel is in either Large icons or Small icons view, click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category view, under View by, click to select either Large icons or Small icons, and then click Mail. The Mail Setup dialog box appears.
  • Click E-mail accounts
  • Select the E-mail tab, click New...
For Windows Vista or Windows XP:
  • If Control Panel is in Classic View, double-click Mail. The Mail Setup dialog box appears.
  • If Control Panel is in Category View, under Control Panel, click Switch to Classic View for Windows XP, or click Classic View for Windows Vista, and then double-click Mail. The Mail Setup dialog box appears.
Alternatively, in Outlook, select the File group at the top.
Click INFO, then add account.
Jun 23, 2011 | Microsoft Office 2010
change font sze of incoming mail on aol
To make Windows Mail or Outlook Express use larger or different fonts for message lists and other interface elements:
  • Select Control Panel from the Windows Start menu.
  • In Windows Vista:
    • Make sure Control Panel Home is highlighted.
    • Click Customize colors under Appearance and Personalization.
    • Follow the Open classic appearance properties for more color options link.
  • In Windows XP:
    • Go to Appearance and Themes if available.
    • Click or double-click Display.
    • Go to the Appearance tab.
    • Click Advanced.
  • Select Icon from the Item: drop-down menu.
  • Choose the desired Font:, Size: and attributes.
  • Click OK.
  • The Icon font is used for the list of folders and messages as well as toolbar icon text in Windows Mail or Outlook Express.
  • Click OK.
  • Jul 10, 2010 | Acer Computers & Internet
    I have to double click the left button to select items on a web page rather than a single click. how do I fix?
    Change the number of mouse clicks required to open items To change the number of mouse clicks required to open items
    1. Open Folder Options in Control Panel.
      • Click Start, and then click Control Panel.
      • Click Appearance and Themes, and then click Folder Options.
    2. On the General tab, under Click items as follows, click the option you want.
    Notes
    • If you click Single-click to open an item (point to select), you can also specify when icon titles are underlined.
    • To check your current browser settings for underlining links, open Internet Options in Control Panel. To open Internet Options, click Start, click Control Panel, click Network and Internet Connections, and then click Internet Options. On the Advanced tab, check the setting for Underline links.
    Jan 06, 2010 | Microsoft Wireless Laser Mouse 5000
    lg vu
    User must be logged in as Administrator or have administrator privileges to modify system files
    Setting up the handset
    1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
    2. Touch the Settings icon located on the bottom of the menu tabs.
    3. Touch the Bluetooth icon.
    4. Touch Turn On.
    5. Touch Settings.
    6. Touch My Device Visibility.
    7. Touch to select On.
    8. Touch Set.
    Setting up the connection
    1. On the PC, double click the My Bluetooth Places icon on the desktop.
    2. Click View devices in range.
    3. If the handset does not appear, click Search for devices in range.
    4. Right click the icon representing the handset and click Pair Device.
    5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
    6. On the handset, an Accept? prompt will appear, touch Yes.
    7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
    8. On the PC, return to My Bluetooth Places.
    9. Right click the icon representing the handset and click Discover Available Services.
    10. Double click the Dial-up networking icon.
    11. When the connection window opens, click Cancel.
    12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
    13. Click the Modems tab.
    14. Click to select Bluetooth Modem and click Properties.
    15. Click the Advanced tab.
    16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
    17. Click OK.
    Making the connection
    3. Right click the icon representing the handset and click Discover Available Services.
    4. Double click the Dial-up networking icon.
    5. Type ISP@CINGULARGPRS.COM in the User name field.
    6. Type CINGULAR1 in the Password field.
    7. In the Dial field, type *99#.
    8. Click Dial.
    You will now be connected to the AT&T data service
    NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
    Apr 22, 2009 | LG Vu CU920 Cellular Phone
    232 people viewed this tip
    David Payne
    David Payne
