Tip & How-To about Computers & Internet
VIEW INTERNET SHORTCUTS FROM THE CHANNEL BAR
View your Internet Explorer shortcuts from the desktop with the Channel Bar. To enable this bar click Start / Run / Type iexplore -channelband and press enter.
Computers & Internet Logo
internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    IE7 flashes briefly when I click on it and then goes away
    This usually happens after installation. 1. Click START–>RUN and type cmd
    2. At the prompt, type cd and press ENTER
    3. Type cd Program Files and press ENTER
    4. Type cd Internet Explorer and press ENTER
    5. Type regsvr32 IEPROXY.DLL
    6. You should get a confirmation that the IEPROXY.DLL has been registered. You can then close all windows and try Internet Explorer again.
    If these steps don’t solve the problem, try
    Launching IE with add-ons disabled:
    1. Click START–>RUN
    2. Type iexplore -extoff
    You can also create a shortcut so that you can always run Internet Explorer this way.
    1. Right-click on the Desktop
    2. New–>Shortcut
    3. Enter in iexplore -extoff
    Hope this helps
    Chris (ziraffa)
    Dec 26, 2008 | Microsoft Internet Explorer 7
    my son did a "system recovery" on my lap top.. Now i cant locate the internet. i found all my files on a back up file but not sure how to get them back.. can someone help me?
    when you say "i can't locate internet" I'm assuming you don't know where the executable icon for internet explorer is, so the following is what you can do to put it back on your desktop or put it back in the start menu.
    first of all make sure internet explorer is avaliable/enable/installed in your computer by going to control panel>add remove programs>add remove windows components and check internet explorer if it's uncheck. then try the following if needed:
    go to start>my computer>local disk c: (or the system drive letter you have on your system) > program files>Internet explorer and in that folder look for iexplore.exe and right click on it and send it to the desktop as a shortcut or pin it the the start menu.
    you can also put it on your start menu by right clicking an empty space on your taskbar (bar wher the start button is .. the blue area), go to properties, go to start menu tab, click customize and put a check mark next to internet and select internet explorer.
    Dec 06, 2008 | Computers & Internet
    change homepage
    To use IE either locate the file IEXPLORE.EXE on your machine and drag a shortcut back to your desktop, or just just type IEXPLORE.EXE in the RUN box, after clicking on START.
    Nov 29, 2008 | Computers & Internet
    Microsoft internet explorer jammed will not open or operate
    Have you tried opening it not only fron the shortcut (icon on desktop) but also by pressing start, internet explorer? If these don't work, try pressing start, run, and type "iexplore" into it.
    MomsyKat
    Sep 16, 2008 | Microsoft Windows XP Home Edition
    172 people viewed this tip
    David Payne
    David Payne
