Tip & How-To about Computers & Internet
INCREASE VIEWING AREA IN INTERNET EXPLORER
To increase the viewing area in Internet Explorer press function key F11. To restore the screen to normal press F11 again.
Computers & Internet Logo
F keys functions
F1
As a throwback to DOS days, you will find that the F1 key will often bring up a help menu. If you press F1 while working in a program, help for that program will usually appear. If you press F1 while at the Windows desktop or when the Windows Explorer is open, a Windows help screen will pop up. If you happen to be working in a program and would like to see the Windows help screen, simply press the Windows key (the key with the Windows logo on the bottom row of keys) on your keyboard and press F1 at the same time.
F2
You can use the F2 key to rename an item when working in Windows. Highlight any folder or file, and press F2. You will then be able to type a new name for the object. After you type the new name, just click outside the name box or press the enter key to make the name change. This works just like right-clicking a file or folder and selecting Rename.
F3
When you are working in Windows, the F3 key will open the Find Files window.
F4
The F4 key has some very useful functionality. You can press F4 to open the Address bar when working in Internet Explorer. This will allow you to type the address of a Web page for quick access.
You can also press the Alt key and the F4 key at the same time to close the open Window that you are currently working on.
F5
The F5 key is the refresh key. You can press F5 when viewing a Web page to make sure that you have the most current version of that Web page. You can also use F5 when in Windows to refresh the screen. This can be a handy shortcut. If perhaps you are viewing the contents of a floppy disk and you insert a new floppy, your screen will still show the contents of the first floppy. Just press F5 to refresh the screen and see the contents of the floppy you just inserted.
F6
This key is often used to move the cursor around the structure of the program. Pressing it will often cycle you from window to window.
F7
The F7 key does not have any functionality in Windows. It may, however be used in some individual programs. To find out if it is available in the program you are using, bring up the program's help screen and type in the words function key.
F8
The F8 key can be used to access Safe Mode if pressed during the computer's boot up process. This is a trouble-shooting mode which will start the computer with minimal drivers.
F9
The F9 key does not have any functionality in Windows. It may, however be used in some individual programs. To find out if it is available in the program you are using, bring up the program's help screen and type in the words function key.
F10
F10 is the key that is used to activate the menu bar in many programs. You can use F10 to highlight the first menu choice, and then use the arrow keys to move around the menus. Pressing the Shift key while pressing F10 will bring up the shortcut menu. This is similar to right-clicking on an object.
F11
Press F11 when you are working in Internet Explorer and the window will open to full screen mode. This will make all the toolbars disappear and can be useful to see more information on the screen. Press F11 when you are in full screen mode will toggle you back to your normal view.
F12
The F12 key does not have any functionality in Windows. It may, however be used in some individual programs. To find out if it is available in the program you are using, bring up the program's help screen and type in the words function key.
Mar 06, 2015 | Dell Dimension Computers & Internet
how to full screen gmail
If you're using Internet Explorer, press the F11 key to switch to full screen view. Press F11 again to bring your URL bar & menus back.
Aug 22, 2014 | Google Gmail
How do I find out what the F keys do on my Asus laptop? and how to use them?
What is the model of you Asus computer. There are a wide rage of differences between them as there are extra functions to them. The basic old school uses are as follows:
F1
F2
F3
F4
F5
The F5 key is the refresh key. You can press F5 when viewing a Web page to make sure that you have the most current version of that Web page. You can also use F5 when in Windows to refresh the screen. This can be a handy shortcut. If perhaps you are viewing the contents of a CD and you remove that CD and insert another CD, your screen will still show the contents of the CD. Just press F5 to refresh the screen and see the contents of the CD you just inserted.
F6
This key is often used to move the cursor around the structure of the program. Pressing it will often cycle you from window to window. In Internet Explorer and Firefox, pressing F6 moves the cursor to the address bar.
F7
F8
F9
F10
F11
Press F11 when you are working in Internet Explorer and many other programs, and the window will open to full screen mode. This will make all the toolbars disappear and can be useful to see more information on the screen. Press F11 when you are in full screen mode will toggle you back to your normal view.
F12
Sep 07, 2013 | ASUS Computers & Internet
Keyboard F1 to F12
F1 - F12 Function Key Usage
Printer Friendly Version
F1:Help. Click F1 Key can load the help file of the program.
F2:Rename. Select a folder or file, click F2 to rename it.
F3:Search. On desktop, click F3 to load the search form.
F4:In Internet Explorer, click F4 will list the URL Address field.
F5:Refresh. Use it to refresh the web page in Internet Explorer.
F6:In Internet Explorer, click F6 will jump to address bar.
F7:It can be used to insert ^C in command prompt.
F8:When windows startup, it can load the startup menu.
F9:In Windows Media Player, it can increase the volumn.
F10:In Windows Media Player, it can decrease the volumn.
F11:In Internet Explorer, click F11 will switch to Full Screen mode.
F12:In MS-Word, it will show out the "Save-As" dialog.
Take this link u will get all the Function Keys description
http://www.computerhope.com/issues/ch000306.htm
Aug 31, 2008 | Computers & Internet
157 people viewed this tip
David Payne
David Payne
