Tip & How-To about Computers & Internet
How to check and change you computer IP address in Windows 7
1. Click on the start button, then click on Control Panel
2. Once in Control Panel click on Network and Sharing Center
3. Click on Change Adapter Settings, located in the upper left hand corner
4. Next right click on the network connection you want to edit and select properties
5. Next highlight (click on to highlight) Internet Protocol Version 4 (TCP/IP) and click on the Properties button.
Note you do not need to worry about the Version 6 as it is not a used standard at this time. The reason the option is there is that it will be a supported feature in the near future.
6. Next you will want to check your network settings. Note in most cases you want these set to obtain automatically. However you may need to change the IP address to a static IP address to access router or printer. Example if the routers IP 192.168.1.1 then you would set the static IP address to 192.168.1.100. Note the last group that I set as 100 could be any number from 1 through 254 as long as it was not in use by another device. So in this case you could not use 192.168.1.1 because it is already used by the router. In addition after you get access to the device you can aways change its IP to fit your networks schema.
**Note I will be adding other links later to this article regarding other changes to this section**
7. Click OK
8. Click Close
After this all your changes should be set. Note some time you will need to reboot your computer to have the changes take full effect.
Click here if you are needing instructictions on how to change your IP address with Windows XP.
Computers & Internet Logo
how do retrieve my IP ADRESS FOR MY COMPUTER & WIRELESS ROUTER
your ISP should be able to help you in that...check with the person with the internet company...
Jul 30, 2010 | Computers & Internet
How to Check Windows 7 Firewall Settings 1. Click on the start button, and then click on Control Panel 2. Once in Control Panel click on Windows Firewall. Here you will see the main firewall settings. Note with the newer versions of Windows, this includes Windows Vista and Windows Server 2008 you now leave the service running. If you want to turn off the firewall you just click on the "Turn Windows Firewall on or off" option. In addition if something networking related is not working properly it may me a good idea to turn off the Windows Firewall for testing to see if the Windows Firewall is actually causing your problem. 3. If you are planning to leave the Windows Firewall running it is a good idea to check your "Advanced settings" Once in here you will be able to check your incoming and outgoing rules, as well as your connection rules. Note if you still have trouble after setting the "Advance settings" there could be another firewall on a computer or on the network in general blocking the communication. If you are communicating from computer to computer in most cases your need to make sure the same firewall changes are on both computers. ----------------------------------------------------- Other Windows 7 Links How to allow ping (ICMP Echo) request through Windows 7 Firewall How to check and change you computer IP address in Windows 7 How to enable and disable printer and file sharing in Windows 7 How to take file ownership in Windows 7 and Windows Vista How to change your drive letter in Windows Vista and Windows 7 How to determine your computer's MAC address
Jun 14, 2010 | Computers & Internet
How to check and change you computer IP address in Windows XP 1. You will need to open your Control Panel. Note there is several ways to do this. XP Start Menu it is on the right side of the start menu. Classic Start Menu it is under Settings 2. Next you need to make sure you are in classic view. Note if you have not been in Control Panel before you most likely will not be in classic view. To put Control Panel in classic view click on the classic view option in the upper left hand corner. 3. Now Control Panel should look something like this. Here is where you would click on Network Connections. 4. Right click on Local Area Connections and select properties. 5. Next highlight (click on to highlight) Internet Protocol (TCP/IP) and click on the Properties button. 6. Next you will want to check your network settings. Note in most cases you want these set to obtain automatically. However you may need to change the IP address to a static IP address to access router or printer. Example if the routers IP 192.168.1.1 then you would set the static IP address to 192.168.1.100. Note the last group that I set as 100 could be any number from 1 through 254 as long as it was not in use by another device. So in this case you could not use 192.168.1.1 because it is already used by the router. In addition after you get access to the device you can aways change its IP to fit your networks schema. **Note I will be adding other links later to this article regarding other changes to this section** 7. Click OK 8. Click OK After this all your changes should be set. Note some time you will need to reboot your computer to have the changes take full effect. -------------------------------------------------------------------------------------------- Click here if you are needing instructictions on how to change your IP address with Windows 7.
Feb 15, 2010 | Computers & Internet
How to set a static IP address in Windows behind a Linksys Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How to set a static IP address in Windows behind a WRT55AG Router
Feb 16, 2006 | Linksys WRT55AG Router
2,223 people viewed this tip
David Payne
David Payne
