Tip & How-To about Computers & Internet
Make Pen Drive To Reset Windows 7 Password
Most of us have a PC at home and one at work. We use our work PC most of the times and home PC comparatively less. Did it ever happen to you that you forgot your Windows 7 Password ? Maybe you go for a month long vacations or business trip and when you are back, you may forget some of your passwords to the home Windows 7 PC.
We tend to have lots of passwords at work, online and at various computers. So to save yourself from a locked out situation, we recommend that you create a password reset disk.
In this article, I will share with you a very simple method to create a Windows 7 Password Reset Pen Drive. So next time you are locked out of Windows 7 at the login screen, you can plug in this USB pen drive in your computer and reset the Windows Password.
To create a Windows 7 Password reset pen drive, I advice to have a small capacity pen drive which is cheap and you should keep it at a safe place, but not so safe that you forget where you kept it when you need it sometime in future.
Follow these simple steps:
Step 1. Insert a pen drive (backup any data if present on the pen drive and delete everything). Then go to Windows 7 Start Menu and type “create password reset disk” in the start menu search and launch the program “Create a password reset disk ” which will be highlighted in the search results.
Step 2. Just follow the simple Password reset Wizard as seen below, by selecting the pen drive from a list of drives it will show you. Note: If you have not inserted a Pen Drive before launching the utility, it will not work and will give an error. If the pen drive is in place, you will see Wizard something like the images below. It will also ask for your current password to create a password reset pen drive.
Step 3. Now you simple need to keep this drive at a safe place. You can use this in case you forget your Windows 7 Password sometime in future, just click forgotten password on the login screen and choose the option to Reset Password after inserting this pen drive into any of the working USB ports of your computer.
NOTE: Windows will honor only the most recent Password reset disk that you have created, so in case you happen to create more than one disk, only the one which is latest will work, all other old password reset disk will not be able to reset the Windows 7 Password.
If you have not created a reset disk and have forgotten your password, you can still reset the password using some utilities like Windows Password Recovery Tool. But these processes may cost you little money if you need to buy a software to do that. So to avoid any inconvenience later, we recommend that you create a password reset disk.
Related source: http://www.lostwindowspassword.com
Computers & Internet Logo
For k_akima The camera operates normally on my work computer and at one time worked fine on my home computer. Something must have changed on the home computer.
Try to go on control panel >> system >> hardware tab >> Hardware manager button (or something like this) then uninstall the web cam. Use some kind of Register cleaner (regcleaner for example). install you web cam again. it should work.
Mar 01, 2011 | Computers & Internet
thecrow_3@hotmail.comis there a difference between vista ultimate and vista home edition as I did find the code but it didn't work
Yes. Vista Home Edition has less features than Ultimate. Also, it will not run on a different code- nor will Microsoft provide you with one if you have the other
Sep 25, 2010 | Toshiba Satellite A135-S2386 Notebook...
my MS home office and student product key not working
As long as it has been installed less than 3 times (less than 3 machines), you can call Microsoft support.
Jun 18, 2010 | RTO Franzis MS Office 2007 Home and...
I want to replace my hard drive in a dell dimensions 4300 pc. The original operating system was Win ME (Dell OEM) with an upgrade to XP Home (Dell OEM). How do I reload the operating system?
If you have the oprating system disk with you thats the most convenient way to install the OS. Else the only option left for you is to contact dell and then order a new OEM disk which costs only $10 - 11 which is very less as compared to the price of a new OS
Jul 15, 2009 | Dell Dimension 4300 PC Desktop
power problem
the left side door is open
Dec 26, 2007 | Canon PC-400 Color Copier
176 people viewed this tip
David Payne
David Payne
