Tip & How-To about Computers & Internet
How to install a new operating system that is not functioning correctly.
Alright, it is not too hard.
This is a tip for a windows computer, this will not be the same on a Macintosh.
1) Take the installation disk of that operating system and put it into the disk drive.
2) Attempt to boot the computer
3) As soon as it starts try using the different function keys (E.G. Like the F12 key, that is the most common one, it may take several tries of turning the computer on-and-off to get the right key.)
4) You should be at the boot menu.
5) Use the up and down arrow keys to choose the "CD/DVD/CD-RW DRIVE"
6) Choose to install windows.
7) If you are careful you can try to get information off the hard drive by using the repair.
8) Choose to re-install windows
9) It will be like when you just got the computer (Maybe not because it won't have any of the Add-ons they usually put in)
Computers & Internet Logo
reformat unmountable flash drive on mac?
Instructions
    • 1
      Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • 2
      Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
      • 3
        Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
      • 4
        Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
      • 5
        Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
      • 6
        Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    May 27, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came with no instructions on reformatting. Please help!
    1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3.
    4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  1. 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  2. 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
    If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
    You also need to make sure the SATA cable is plugged into the right place on the board.
    SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
    If this is an addon drive then
  3. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  8. I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
    Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
    1. Connect the external hard drive to your mac.
    2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    3. Select the external hard drive that needs to be formatted on the left.
    Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
    Apr 28, 2011 | Computers & Internet
    How do I format my new WD Elements SE 500GB for Mac OS Snow Leopard
    hi.
    follow instructions below
    1> Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2> Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3> Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    4> Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
    5> Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    6> Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    regards
    Apr 23, 2011 | Western Digital Wd Elements Se 1tb...
    181 people viewed this tip
    David Payne
    David Payne
