Tip for PowerShot A520 Digital Camera
Explaining Camera Focus
posted on Mar 21, 2008
early1234
early1234
Rank: Wiz
Rating: 84%, 728 votes
Camera: Focus We've seen that a real image is formed by light moving through a convex lens. The nature of this real image varies depending on how the light travels through the lens. This light path depends on two major factors:
  • The angle of the light beam's entry into the lens
  • The structure of the lens
The angle of light entry changes when you move the object closer or farther away from the lens. You can see this in the diagram below. The light beams from the pencil point enter the lens at a sharper angle when the pencil is closer to the lens and a more obtuse angle when the pencil is farther away. But overall, the lens only bends the light beam to a certain total degree, no matter how it enters. Consequently, light beams that enter at a sharper angle will exit at a more obtuse angle, and vice versa. The total "bending angle" at any particular point on the lens remains constant.
As you can see, light beams from a closer point converge farther away from the lens than light beams from a point that's farther away. In other words, the real image of a closer object forms farther away from the lens than the real image from a more distant object. You can observe this phenomenon with a simple experiment. Light a candle in the dark, and hold a magnifying glass between it and the wall. You will see an upside down image of the candle on the wall. If the real image of the candle does not fall directly on the wall, it will appear somewhat blurry. The light beams from a particular point don't quite converge at this point. To focus the image, move the magnifying glass closer or farther away from the candle.
This is what you're doing when you turn the lens of a camera to focus it -- you're moving it closer or farther away from the film surface. As you move the lens, you can line up the focused real image of an object so it falls directly on the film surface. You now know that at any one point, a lens bends light beams to a certain total degree, no matter the light beam's angle of entry. This total "bending angle" is determined by the structure of the lens.
courtesy of HowStuffWorks.com
Helpful
Was this helpful?
Yes
No
1 person thought this was helpful
Add A comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Digital Cameras problems?
Answer
it was dropped with lens fully extended. lens is retracted and not exactly straight when turned on... (More)
Answer
Batteries need charging message very often, even, with new fully charged or new non rechargeable... (More)
Answer
Re. Canon PowerShot A520. Lens is stuck about 97% open. The camera will not power on. The problem... (More)
Answer
LCD display shows up so light that if there is any light where I take a picture I can't see it in... (More)
Answer
The camera will not turn on even with fresh batteries. Is there any combination of buttons i can... (More)
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
