Tip & How-To about Computers & Internet
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
Computers & Internet Logo
how to activate facebook without wifi?
Accessing Facebook needs internet connection. Without any active connection, you will not be able to connect to internet.
Internet connection option for such devices:
Mobile phone:1. GPRS - settings will be coming from your mobile service provider, data rates will be deducted from your load credits.2. Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Laptops / computer / PSP:1. USB Dongles - this will use the gateway connection via BTS for its using the internet connection like the protocol of ISP.2. Wi-fi - Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | Myphone Computers & Internet
where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
Only internet light is blinking
According to the user guide, the modem is trying to connect to the isp. If it is continually blinking, check all your cables. Once you are satisfied all cables are properly connect contact the isp to find out if there is an outage in your area and if not they can help you.
May 25, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
what do i need to access the internet FOR FREE ( PUBLIC ) DO I NEED SOMETYPE OF HARDWARE / THE COMPUTER DIALS UP BUT ASK FOR SOME KIND OF KEY.
you have much to do
it depends if you are using phone or a modem then you will have the software Ultrasurf on your system and you will use that along with your phone that browse or modem that have facility to connect but not browsing because you dont add to your tariff plan so then you configure easily and that will solve your question
Feb 22, 2010 | Computers & Internet
i cant connect to two computers at the same time
How to connect....
1- Two Computers:
# We are connect two computers together to share Internet, printer, scanner, files, and even programs
We can do it through either way:
1- Use A Crossover Cable And Two Network Cards.Two network cards are installed in two computers.Then use crossover cable to connect them.
2- Use a Phone Line and Two Special Adapters Sold as "Phone line network Kit". Two adapters are installed in two computers. Then use existing Phone line to connect them.
Connecting Two Computers Wirelessly:
1- Wi-Fi
2- Bluetooth
3- Infrared
Several types of fixtures exist for home networking:
1- Hubs
2- Switches
3- Routers
2- Computer with the internet
Before you can connect to the Internet and access the World Wide Web, you need to have certain equipment. In brief, you must have:
-A computer (preferably running an up-to-date operating system); -
-A modem and access to a telephone line or a local area network (LAN) that is in turn connected to the Internet; and connection software that will allow you to establish an account with a service provider and access the Internet
You Need:
Modem: This converts your digital computer information into analogue telephone signals. Phone Line: his may be your biggest expense after the equipment.
Internet Service Provider (ISP): ISP has a permanent connection to the Internet.
ADSL: a newly standardized transmission technology facilitating simultaneous use of normal telephone services, data transmission of 6 Mbit/s in the downstream and Basic-rate Access (BRA).
ADSL facilitates the simultaneous use of normal telephone services, ISDN, and high speed data transmission.
Another advantage of having an ADSL line is not missing calls while you're online, as both voice and data can be transferred at the same time.
Jun 19, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
1,829 people viewed this tip
David Payne
David Payne
