Tip & How-To about Computers & Internet
How to connect to wireless on the laptop or wireless enabled desktop.
1.Connect modem to the router and router the laptop.
However, if you have a modem- ***-router, connect it to the laptop.Note: Modem must be connected to one separate port of the router on which you would find generally mentioned as LAN, WAN, Internet.Also Laptop must be connected to one of the four ports of the router.Now, check if you are able to go online or not.
2. If you are not able to go online after connecting the cables mentioned in the step one, bypass the router and check if you are able to go online or not. If you are able to go online after bypassing the router, you can reset the router by holding down the reset button for 30 seconds or inserting a paper-clip and rotating it gently for 30 seconds inside the small hole on the router.
If you are not able to go online after bypassing ther router as well, please use link given below:
http://www.fixya.com/support/r4561845-fix_internet_issue_page_cannot
3. Now, once you are able to go online with the wires connected to modem and router, please follow the following steps given below:
A. Check if the wireless adapter drivers is installed properly or not.
Click start, right click "My Computer", click Manage, click Contiue(if you see any), Click Device Manager on the left-hand side. Now, on the right-hand side, click + sign in front of the Network Adaptor. Under Network Adapter, check if you see any wireless adaptor. If you see it is properly installed, then you can move to step B. If you do not see any wireless adapter installed, you can install it from the manufacture's website. However, if you see any red mark in front of the wireless adapter, you right- click it and enable it. If you see any yellow mark, you can right-click on the wireless adaptor and click Uninstall and click OK. Now, restart the computer.
B. If you are using router for the first time on this laptop or wireless capable desktop, you can insert the disk that came with the router inside the lapop and follow the on screen instructions.
C. Now, check the default gateway address, under "Ethernet Adapter Local Area Connection".
i). Click Start, click Run, type in "cmd" in the box and hit enter.(In Widow Vista and Window 7, Click Start, and type in the 'Start Search' box, 'cmd', Now, right-click 'cmd' at the top and click 'Run as administrator'). Now, on the black screen, type in 'ipconfig'. You will see default gateway address under "Ethernet Adaptor Local Area Connection". (IPV4 in case Window Vista and Window 7).
ii). Now, launch internet explorer or any of the other browser like Mozilla or Google Chrome.
iii.) Delete everything from the address bar(http://www box) and type in default gateway address (like 192.168.....1).
iv)Now, it would show you router page and ask for the usename and password of the router.
v) If you have yet not set any password on this router page, you can try the default usename and password for the router and password.You can use the link below to find the default usename and password for the router:
http://www.phenoelit-us.org/dpl/dpl.html
vi)Now, once you enter the correct default usename and password for the router login page, you would see router settings page.
vii) Check and find wireless security or security.
Viii)Set a service set identifier (SSID) to identify the router and change the password.
ix)Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
x) Now, click save settings.
D. Enable the wireless services of the operating system.
Click Start, click Run, type in "services.msc" in the box and hit enter.(In Widow Vista and Window 7, Click Start, and type in the 'Start Search' box). Search for wireless zero configuration(WLAN autoconfig) and double click on it. Start up type must be automtic and Start button must be grayed out. If Start up type is Manual, make it automatic and click Start button to make grayed out..
4. For Window XP:
Click Start, click Run, type in "ncpa.cpl" in the box and hit enter:
i) You would see Wireless Area Connection. Right click it and click properties.
ii) Click tab, Wireless Networks.
iii) Make sure check box is checked, use Window to configure my wireless network settings. If you see it blank, click on it and you would see a green check mark inside.
iv).Under preferred Network, select all of the wireless one by one and click remove.
v) Now, click view, wireless network.
vi)Find your network, click it ,click connect and enter the security key. You would be connected to wireless. You can now disconnect the ethernet cable from the laptop.
Note:If you do not see any nework go to step 5. Follow the instructions mentioned there and again follow this step.
For Window Vista and Window 7:
i) Go to Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage wireless network.
ii) Find the network icons, right click them and click delete or remove.
iii) Click Start, and type in the 'Start Search' box, "ncpa.cpl".
iv) You would see Wireless Area Connection. Right click it and click connect/disconnect.
v)Find your network, click it, click connect and enter the security key. You would be connected to wireless. You can now disconnect the ethernet cable from the laptop.
5. Turn on the wireless capability on the laptop.
On laptop body, you would see a button to turn on the wireless capability. You can turn it on manually.or in some of the latop you can hit Fn+F2 key or F2 key.You can check the manufacurer website to know how to turn on the wireless capability of your laptop.
Computers & Internet Logo
l cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are unable to connect to the wireless connection. It will show "connecting" and then just "close" with no messages. I've resettted my router but am still unable to access the router configuration page. Previously i am able to access my router configuration page through the webpage "192.168.1.1" but after my modem replacement, i'm unable to access the page.
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Attempting to connect netgear 624 to modem with desk top computer
first call comcast that you'll use a router with the modem.
then connect the cable modem to the router.
then connect the desktop to the router and use the supplied cd.
Dec 12, 2008 | Computers & Internet
how to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
734 people viewed this tip
David Payne
David Payne
