Tip & How-To about HTC Touch Cellular Phone
HTC Touch Clear Storage
Clear Storage
Another way of clearing the device storage and reset all settings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
  1. Tap Start > Settings > System tab > Clear Storage.
  2. Enter “1234” then tap Yes.
I hope that helps.
________________________
Download the HTC Touch Manual.
HTC Touch Soft Reset.
HTC Touch Hard Reset.
HTC Touch Cellular Phone Logo
i have buy a new htc p3470 mobile fone.i have a
try a hard reset of your phone:
this will get you back to factory default and take you through wizard for setup.
To perform a hard reset
1. Remove the back cover.
2. Press and hold the SOFT KEYS, then use the stylus to press the RESET
button located below the battery compartment.
3. Release the RESET button, but
continue pressing the SOFT
KEYS until you see this message
on the screen:
4. Release the SOFT KEYS, then
press TALK/SEND to perform the
hard reset, or press any other
button to cancel the reset.
This operation will delete
all your personal data,
to manufacturer default.
Press Send to restore
manufacturer default, or
press other keys to cancel.
Clear Storage
Important If Encrypt files placed on storage cards is or was enabled before, then
backup all files from the storage card before using Clear Storage, hard
reset or updating the ROM system software. Otherwise you will no longer
be able to access the encrypted files on the storage card. Use ActiveSync
or Windows Mobile Device Center to transfer files between your storage
card and computer. After the procedure, copy your files back to the
storage card.
2. Enter “1234”, then tap Yes.
Your device restarts and displays the Quick Setup Wizard
Mar 27, 2010 | HTC P3470 Smartphone
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
1.
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
3.
Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
How can I do Hard reset my HTC S730 ?
1) Click Start
2) Click Expert
3) Click "Clear storage"
and follow on-screen instructions to reset your phone.
REMEMBER that all of your data will be deleted and the phone returns to factory deafult settings.
That should be all :)
Aug 21, 2009 | HTC FUZE Smartphone
I need to reset my password for my Sprint HTC Touch MP6900
Hard Reset
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
Release the TALK and END buttons, and then press ENTER on your device.
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Another way of clearing the device storage and reset all setings back to factory default settings is to use the Clear Storage feature. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first.
Nov 20, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Hard reset for a HTC Touch Diamond
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
2,362 people viewed this tip
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
