Tip & How-To about HTC Touch Cellular Phone
HTC Touch Soft Reset
Soft Reset
Occasionally, you may need to reset your device. A soft (or normal) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
To perform a soft reset
Use the stylus to press the RESET button found at the bottom of your device. Your device restarts and displays the Today screen.
I hope that helps.
____________________
Download the HTC Touch Manual.
HTC Touch Clear Storage.
HTC Touch Hard Reset.
HTC Touch Cellular Phone Logo
My HTC Desire HD has just frozen. The screen is now black and no buttons work. When I connect it to the battery to the mains I get the coloured welcome screen for a few sceconds but then it goes black again. Any ideas?
Please reset the mobile ,
Resetting Your Device Soft reset Occasionally, you may need to reset your device. A soft(or normal) reset of your device clears all active program memory and shuts downall active programs. This can be useful when your device is running slower thannormal, or a program is not performing properly. A soft reset is also necessary afterthe installation of some programs. If a soft reset is performed when programs arerunning, unsaved work will be lost. To perform a soft reset 1. Remove theback cover. 2. Use the stylustip to press the RESET button located between the SIM card and the storage card slots. Your device restarts and displays the Home screen. Hard reset You can also perform a hard reset (also known as a fullreset). A hard reset should only be performed if a normal reset does not solve asystem problem. After a hard reset, the device is restored to its defaultsettings-the way it was when you first purchased it and turned it on. Any programs youinstalled, data you entered, and settings you customized on your device will be lost.Only Windows MobileĀ® software and other pre-installed programs will remain. Warning! Your device will be set back to factory default settings. Make sure thatany additional installed programs and/or user data have beenbacked up before you perform a hard reset. Managing Your Device Important IfEncrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset,or updating the ROM system software. Otherwise you will no longer be able toaccess the encrypted files on the storage card. Use ActiveSync or WindowsMobileDeviceCenter to transfer files between your storage card and computer. After theprocedure, copy your files back to the storage card. To perform a hard reset 1. With thedevice turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button. 2. Continuepressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen: This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel. 3. Release theVOLUME UP and VOLUME DOWN buttons. 4. Press theVOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | HTC Touch HD Smartphone
hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
how to remove align screen
Hi..
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
regard,
adhiwahyudy
Dec 24, 2010 | i-mate JAQ3 Smartphone
phone is stuck on setup
If it is stuck or frozen:
Do a Soft reset
Or:
Do a Hard Reset
(THIS WILL REMOVE ALL APPS BUT NOT YOUR PICS AND MUSIC!!)
  • Slide open keyboard
  • Press Alt and L at the same time you will get a screen with some options listed
  • Press Alt and W at the same time to wipe device to factory reset
  • Once it is finished press home and back key at the same time
  • Remove the battery
  • Reinsert the battery
This will wipe your device to factory reset. You will need to log in to your gmail account like you initially did.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 16, 2009 | HTC G1
hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
1,738 people viewed this tip
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
