Tip & How-To about Computers & Internet
What should I backup ?
When you have problems with your pc or laptop it can be too late to save everything. Even if you have the time you usually forget something. Those you usually remember after the drive has been replaced or formatted and everything is long gone.
Let's say windows is acting up or your hard drive or computer isn't doing too well so it is headed into the shop to get fixed. The tech says they may have to format or replace the drive. They usually won't remind you to back anything up. They just warn you they may wipe it out. If you had the time and everything was behaving you could so a complete backup. I've never seen anyone actually want to do one of those until the computer was having problems and by then it is way too late.
The easiest way to do this is by using the files and settings transfer wizard. It is located under the system tools folder on your start menu. This will get most of what you need but you want to check. Simply run it and select the old computer option then it will ask where to save to and it will also let you look and change what file type it backs up. It may not get everything important so check.
When you back up file while there is a problem you can't count on the machine so you need to prioritize and get the important stuff off first. Once that is safe then you save off files that are annoying to replace but can be with a bit of work. And last you want to backup things that are annoying such as favorites and email addresses.
So what you need to do first is backup important and irreplaceable files. These are things like letters or documents you have written, perhaps pictures. Think about the files that the programs and you have spent hours or more creating or you cannot replace. Those are the things you want to save off first.
Next you want to save things like address books, favorites and other types of things that you generate while using the computer. Email addresses are not hard to replace over time but it can be annoying if you can't find one if you need it right away. Favorite web sites are easily saved but if you spent hours looking for something and just stumbled across what you need it gets rather annoying to try and find it again. If you do a lot of searching you know just how hard it can be to find the same page. The idea is to look at each program you use or thing you do on your computer and the look at what you need to save off. Somethings can be more important to you so you may want to save them off earlier.
Programs are never important you can always install those again.
There are somethings you may need to export instead of copying off. This will export or save things to a file and then you just copy the file off to somewhere safe.
So as you look at this you should see that you want to save things off in priority. If the drive or computer keeps on working fine, but what if it quits and all you had saved was a few funny emails. You will not be a happy camper to say the least.
If you are not connected via a network to another computer then the best thing you can use is a USB flash drive. These are fast, cheap to buy and can hold a lot of stuff. It is worth going over this once before you have problems so you get an idea of what and where to find things. Much easier and way less stressful while the computer is running properly.
Computers & Internet Logo
Forgot my bios password and cannot get into my computer,how do I get rid of the password?
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
remove-battery.thumbnail.jpgAnyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
remove-bios-battery.thumbnail.jpgMake sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Jun 01, 2011 | Toshiba Computers & Internet
I am getting a message that reads something like "Realtime Clock Error # ?" And then the machine will not operate even so much as to loak the OS.
Hi:
usually this error is caused by your CMOS battery being dead.
You can verify that by getting into your BIOS and checking the date and time on your laptop.
If they are wrong, then usually that is the cause. Replacing that battery varies by model, but usually, if you go in, set the time, and save it,and the laptop is still powered up, the time will stay accurate, enough to load an OS, and once you unplug it, will need reset again.
Oct 07, 2010 | IBM Computers & Internet
I have I laptop dell inspiron 1525MY problem is when I turn on they say is protected by A password authentication system.... how I remove the password help me
HI
How to Bypass or Remove a BIOS Password by Removing the CMOS Battery:
remove-bios-battery.thumbnail.jpg Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
Jul 04, 2010 | Computers & Internet
After working flawlessly for months my wireless g router suddenly quit working wirelessly. I can connect my pc via ethernet cable to router and everything works. The wlan light is on constantly but my laptop (or Ipod) can't detect the signal. What can I do? I've tried downing the pc cable modem and router several times. I even reinstalled the router -- nothing helps.
You can try the steps below and see if it will fix your problem.
1. Log in to your router interface by opening a browser. On the address bar type in http://192.168.1.1. ( this is usually the default address of linksys router)
2. Once you press enter, it will prompt you for a username and password.
Dont type anything on username and enter on the password box, the word admin.
3. Once your inside the router page, Click on wireless tab.
under wireless tab, change the wireless channel to 1, 6, or 11. If the ssid is still linksys, change it to something different. After doing these steps, press save settings. TO save the changes you made.
Jun 27, 2010 | Linksys Wireless-G WRT54G Router
windows trogan?
ya its probably a virus infection.
If possible run online scans... or install new antivirus software and scan your sys.
If nothing of this is possible or if they are not working..
its safer to reinstall Vista
Apr 21, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
159 people viewed this tip
David Payne
David Payne
