Tip & How-To about Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 265W Favorites Backup
Garmin Nuvi 265W Favorites Backup and Restoration Procedure
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi 265W Hard Reset Here.
Download Nuvi 265W Manuals here.
Download Garmin Nuvi 265W WebUpdater here.
Garmin Nuvi 265W GPS Receiver Logo
Garmin Nuvi 265W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270 Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275 Does your Garmin Nuvi 265W Freeze at Loading Maps? Does it lock up or stop working? This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater. A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. Backup and Restoration Procedure for Favorites: The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.Perform the Hard Reset: *Note that this will clear all user selected settings on the unit Power the unit off. Remove the battery and wait several minutes. Install the battery. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears. Press "yes" and the unit will reboot. This resets all your location settings and user preferences. If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data. You have now performed a hard reset of your Garmin Nuvi 265W GPS unit. I hope that helps. ______________________ Backup & Restore Nuvi 265W Favorites here. Download Nuvi 265W Manuals here. Download Garmin Nuvi 265W WebUpdater here.
I had a distorted speaker that wouldn't recover it's voice. I tried all the suggestions on here and nothing worked. I settled on taking it apart to look at the speaker. My warranty expired and the cost of repair exceeded the value of the unit, so I took a chance. Tirns out the speaker was clogged with metal particles. I blew them out with compressed air from a can used for cleaning computers. It works like it should but I suggest Garmin should have a filter inside the speaker grill of these units.
Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
5,866 people viewed this tip
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
