Tip & How-To about Sony Cyber-shot DSC-H7 Digital Camera
Sony Memory Stick Formatter
Sony Memory Stick Formatter Software
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
Sony Cyber-shot  DSC-H7 Digital Camera Logo
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped working in your digital device, Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device. Compatible operating systems include: * Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate * Windows Vista® Home Basic / Home Premium / Business / Ultimate * Windows® XP Home Edition / Professional * Windows® 2000 Professional Preparation * Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position. * Insert the Memory Stick into the Memory Stick slot of the device or computer. * If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process. The Format Process Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data. * To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter. * At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot. * Click the Start Format button. * At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button. * Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption. * At the "Format was successful" message, click OK. * To quit the Memory Stick formatter utility, click the Exit button. Download the Sony Memory Stick Formatter Here. I hope that helps. ____________________________________ Click here for Sony's Memory Card File Rescue software.
Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
1,782 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
