Tip & How-To about Pioneer PDP-4280HD 42 in. Plasma Television
Pioneer PDP-4280HD Manual
Model: PDP-4280HD / PDP-5080HD
Have you lost your Users Manual / Owner's Guide for your Pioneer PDP-4280HD?
Would you like a digital copy of the Owners Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Pioneer PDP-4280HD users guide.
Pioneer PDP-4280HD 42 in. Plasma Television Logo
cant get picture when dvd selected on pioneer pdb r040
try a full factory reset then check to see if someone has turned on the mode or channel block, some tv,s you can block the dvd mode through the parental guide lock
Mar 31, 2013 | Pioneer PDP-4280HD 42 in. Plasma...
How to replace the mainboard on my pioneer pdp 5080hd? i think its the mainboard. all my HDMI inputs and component inputs wont work but everything else will. anything will help!
Lay the TV on a soft flat surface, then you just have to remove the stand and all the screws on the back, then the board mounting screws and connectors. Best thing to do is to take a lot of pictures so you will know how it goes back together. Mark the connectors with marking pen also.
Also look for any bad caps with domed tops when you are at it as well.
Boards:
http://www.shopjimmy.com/catalogsearch/result/?q=Pioneer+PDP-5080HD
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Pioneer PDP-5080HD 50 in. Plasma HDTV
My Pioneer PDP-4280HD Plasma - Have never been able to get the TV Guide feature to work. Only some of the set up screens are shown in the manual. Can someone help? I see the feed of channels, which is correct, but it always shows as searching. the inputs are correct... as it sees the channels. on the listing page, it shows things like what channel to set it on like 2 or 3 or 4. I've tried those and it never gets the listings.
My research into your set and its TV Guide feature brought up two points that may be relevant:
  1. It apparently takes about 24 hours for the guide to load up completely. This would make it difficult to get real-time info as to whether it was working or not.
  2. 'TV Guide' may not work will all providers, and may not work as providers switch to digital. Have you spoken to your provider about possible compatibility?
I hope that helps
______________________
Click here for a Pioneer PDP-4280HD manual.
Apr 17, 2010 | Pioneer PDP-4280HD 42 in. Plasma...
2,423 people viewed this tip
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
