Tip & How-To about Computers & Internet
How to transfer your old files to Window 7
Before beginning i recommend performing a full backup so that if anything goes wrong you can roll the system back to working state.
1. You might have a large number of files on your computer that you've either downloaded.The chances are you've also not accessed many of these files in years.
Take time to make an assessment of which files you actively use. In many cases, you'll find that you can free up large amounts of disk space by simply archiving old files. Do this now to clear space and you'll save them later on.
2. Download Microsoft windows easy transfer from http://tinyurl.com/windowsET. Select the correct version depending on whether your old windows installation is XP or Vista, and 32-bit or 64-bit. If your not sure with vista, click start ,type system and click system in the programs list. In XP, click start then Run.Type system.cpl and press Enter. In each case it will tell you if your current version is 32-or 64-bit.
Once downloaded , double click on the easy transfer file and follow the installation wizard.
3. Run windows Easy Transfer from the start menu. The initial screen tells you what it can do. Click Next to continue. The next screen asks which transfer method you want to use. If you're transferring files using and external device, click the bottom option. Click Next again, and you'll be asked which computer you're using, click it.Windows Easy Transfer now builds a list of your files and settings. This process may take several minutes.
4. Easy File Transfer will identify the data it plans to transfer for each user account, and also from shared locations. Review files using the Customise buttons. This displays a sub-window,allowing you to select what you want transferred. If you need to remove files from the list,click advanced.
You can then deselect files by un-ticking the check boxes.
Click next, enter password if required, then click next again to select a transfer destination. The program creates an archive and tells you where it's stored. You can now exit the wizard.
5. Install Window 7 using the disc supplied. When complete, insert your USB drive and open it to display its files. These are stored as a self-extracting archive, so there's no need to install easy files transfer on windows 7.
Double-click the files from old computer. After a few minutes you'll be presented Whit a similar window to the one you saw earlier when you created the archive, but this time you're choosing files to load to a new computer. You can click Customise to omit files, as before.
6. Click Transfer to start loading the files on to the new computer. To prevent file corruptions or access conflicts, Windows 7 deliberately hides the menu bar to prevent you from using the PC until the transfer is complete.
Finally, click on the option to see the files that were transferred. Clicking the Program report tab also lists any third-party applications, such as adobe reader, that windows 7 thinks you'll need to install to access your files.
We are done now wish you luck' and please leave comment and feedback.
thanks
Computers & Internet Logo
system recovery/restore on my A015-S1014?
Perform a "System Restore" This is the best option; it will “restore the system” back to a previous state, to undo the change. 1. Go, to: "Control Panel". 2. Click System and Maintenance. 3. Click Backup and Restore Center. 4. In the (left) Tasks area, click on Repair Windows using System Restore.” 5. The restore “Wizard” appears. 6. Choose (Recommended) Restore Point. Important! If this, restore point fail? Try again using a different “restore point.” Find the “furthest” (Date) prior to when your computer was functioning normal. 7. Follow all instructions thereafter. *Note: “Once the computer returns to Windows Desktop, “do not perform any tasks, for at least (45 min) the System Restore is still “running." I hope this Fix it.
Jan 31, 2010 | Toshiba Satellite A105 Notebook
i uninstall something to my laptop i cnt remember what it is, then when i insert my headphones it doesnt work but when its working on headphones my laptop doesnt work, what should i do?
Perform a "System Restore" This is the best option; it will “restore the system” back to a previous state, to undo the change. 1. Go, to: "Control Panel". 2. Click System and Maintenance. 3. Click Backup and Restore Center. 4. In the (left) Tasks area, click on Repair Windows using System Restore.” 5. The restore “Wizard” appears. 6. Choose (Recommended) Restore Point. Important! If this, restore point fail? Try again using a different “restore point.” Find the “furthest” (Date) prior to when your computer was functioning normal. 7. Follow all instructions thereafter. *Note: “Once the computer returns to Windows Desktop, “do not perform any tasks, for at least (45 min) the System Restore is still “running. “ I hope this Fix it.
Jan 26, 2010 | Microsoft Windows Vista Ultimate Edition
my camera isn't working i having done anything is
To, perform a System Restore! is the best option; it will “restore the system” back to a previous state, to undo the change. 1. Go, to: Control Panel. 2. Click System and Maintenance. 3. Click Backup and Restore Center. 4. In the (left), Tasks area click on Repair Windows using System Restore.” 5. The restore Wizard appear. 6. Choose (Recommended) Restore Point. 7. Follow all instructions thereafter. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running. I hope this Fix it.
Jan 15, 2010 | Acer Aspire 5610-4648 Notebook
backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
116 people viewed this tip
David Payne
David Payne
