Tip & How-To about Computers & Internet
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
Computers & Internet Logo
The power switch is not turning the computer on.
switch problem / motherboard problem / smps
1 change power switch
2 check smps
3 mother board supper io check
remove power switch and short two lege
Feb 08, 2011 | Acer Aspire AX1800U9002 (PTSBW02001) PC...
motherboard fails to start
Hi there please try the steps below.
1.Remove the RAM & CPU then check its working or not. Changes of damage is RAM, Processor, & Motherboard power supply system.(SMPS). Thanks & hope you will short out your problems. Waiting for your feedback.
Mar 15, 2010 | Computers & Internet
cannot turn it on.
HI there, please follow the steps below.
1. Check the batteries. 2. After remove the battery Turn on the system by power adaptor and see what's going. 3. Run by battery only and watch. if all of these showing the same result, then 4. remove the RAM & CPU then visit a service center for checking its working or not.
Mar 15, 2010 | Acer Aspire 5610-4648 Notebook
N15235 win fast motherboard
The main cause behind this problem is :-
1) RAM JAM
2) HDD is taking extra power from SMPS
3) Motherboard faulty Capacitors / ICs
Try following :0-
step 1) Remove CMOS Battery (3V battery) + RAM
and now try to check whether Fan shows same symptoms or not
Step 2) if results of above step is fail then try to remove HDD powersuppy + CD/DVD power supply + Floppy Power supply (in short provide power to only motherboard) and now start the system.
If the result are same
3) then look for any swollen capacitors on motherboard, if they are then you need to replace them.
4) If no capacitor is swollen then check for every bigger IC on motherboard for whether it got excessive heated or not. If yes then you need to do serious operations on your motherboard .
Please not here i have used the word EXCESSIVE HEATED. and noth the normal heated
May 29, 2008 | Computers & Internet
broken connection on power jack
for Aspire 5100
follow this step.
from backside
1. remove battery
2. remove hard drive cover and hard drive
3. remove the thermal cover, remove wireless card and antena cable.
frontside.
1. remove the power button cover.
2. remove keyboard.
3. remove lcd cable, wireless antena.
4. remove the lcd screw (2 long screw and 2 short screw)
5. remove the lcd screw from the back side (2 short screw).
now the lcd is separated from laptop body.
from backside again,
1. remove fan, there are 2 screw that hold the fan
2. remove heatsink (4 very short screw)
3. remove all screws from backside, there is 1 screw hidden "under" heatsink. it's short scew (longer than heatsink screw).
from frontside, remove 2 screw on top part of the laptop body.
and than you can remove the uppercase now.
after you remove the uppercase, remove 2 screw that hold modem, and remove 1 screw (very short) on bottom part, it's close to touchpad button. remove power switch board and modem and then remove the speaker cable and mic cable.
that's all you can take out the motherboard.
note: just remember to use the correct screw when you put it back.
i hope this will help.
Feb 26, 2008 | Acer Aspire 5100 Notebook
366 people viewed this tip
David Payne
David Payne
