Tip & How-To about Computers & Internet
Resetting BIOS manually.
Most of you guys may know this already, Any how some people still as k this question. So if anything goes wrong with the settings of the BIOS and you are unable to change the settings back you will need to reset bios manually. to this the easiest way is to remove the Button cell on the PC`s motherboard and wait for 10-20 seconds and re insert it. Your BIOS will be reset, Also most motherboards have a button or a jumper to reset the bios but you will need to consult the documentation that came with the motherboard to locate it.
Hope this tip helps some pepole out.
Computers & Internet Logo
when i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
Hello! I would like to know how to disable the onboard video card on Asus P7H55-M Pro mainboard... could you helo me please? thanks!
Hello ,
Just go to the bios settings and find the option to disable the onboard video. But make sure to that your booting video is pci.
You can set those options in bios settings.
To go to bios settings.tap the del key or f1 or f2 key continiously the minute you turn on the system.
If something goes wrong try removing the small battery cell from your motherboard and fix it back again in 5 min.
Oct 21, 2010 | ASUS P7H55M PRO (90MIBBB0G0EAY0KZ)...
i cannot seem to update the bios, it keeps saying jumpers not set properly. in the bios screen it says boot sectors is set to erasable. my machine type is the acer power 1000 (w athlon chip)
1. Don't flash your BIOS unless you really need to. If you got a reason for flashing your BIOS, by all means, but remember that If you load the wrong version or something goes wrong, it's a new motherboard that you will be needing.
2. Get the correct install procedures from the makers of your motherboard or the place where you downloaded the BIOS update from. If you know how to read, you know how to do it. There is nothing very complicated here.Be safe and good luck. :-)
Nov 15, 2009 | AcerPower 1000 - Athlon 64 3800+ 2.4 GHz...
Black screen!
lets check a couple of things. I'm sure you know that a laptop can be hooked up to a external monitor or projector, There is a button usually F5 Or close to it that will turn your monitor off and send it to the external one. In some models of toshiba this will stay in effect even when you turn it off. You can toggle this setting by holding the FN key down and pressing the appropriate "f" key. try this first before you chuck it. There also may be a problem in the bios. Let me know how it turns out. Take care..Be mucho blessed... Mark
Jun 28, 2008 | Compaq Presario R3000 Notebook
faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
254 people viewed this tip
David Payne
David Payne
