Tip & How-To about Microsoft Office Outlook 2007 for PC
How to disable "Perform an automatic send/receive when exiting" in Outlook 2007
If you are having trouble with Outlook closing it is possible that there is a problem with Outlook its self. However one of the things that I have found is that the "Perform an automatic send/receive when exiting" option is turned on. Below is the steps to check to see if this in enabled in Outlook 2007.
1. Click on Tools then Options in the menu bar.
2. Once in Option click on the Mail Setup tab
3. Click on the Send/Receive button.
4. Make sure "Perform an automatic send/receive when exiting" is unchecked
5. Click Close
6. Click OK
Note normally in a corporate environment this is not turned. If "Perform an automatic send/receive when exiting" was already disabled and you are still having trouble with Outlook closing you may need to reinstall Office on the computer.
Microsoft Office Outlook 2007 for PC Logo
Problem with Microsoft Outlook 2007
As the issue happens during sending and/or receiving of emails, the usual suspects are having a virus scanner installed which integrates itself with Outlook or having a corrupt srs-file(srs stands for: Send Receive Setting).
The solutions in this case are quite easy;
§Disable your virus scanner's integration with Outlook
This is a recommended procedure anyway, even when you don't have the error. For more background information about this see: Disable virus scanner integration?
§Reset your srs-file
The srs-file contains the settings that you set via the Send/Receive dialog in Outlook (CTRL+ALT+S). To reset it, simply rename it to .old when Outlook is closed. For more information and step-by-step instructions see: Cannot Edit Send/Receive Settings
Also you can use these steps:
Go to C Drive> Program Files> Microsoft Office> Office 2007. After doing this you will see the PST files. Right click on it and go to the Properties and then select the Compatibility tab. Click on it to clear down all the Compatibility Mode Check Box. After doing so, click on Apply and then press OK. Restart the computer and your problem is sorted out.
If it useless use special tool.
See more: http://www.oemailrecovery.com/outlook-recovery.html
Regards!
May 19, 2015 | Microsoft Office Outlook 2007: Windows
my microsoft outlook 2007 restarts while downloading mails
Close outlook and search for *.SRS files once you find the files delete it open Outlook
srs files are for sending and recieving mails in Outlook
Mar 03, 2009 | Microsoft Outlook 2007 Full Version Volume...
Outlook problem: Constant synchronizing files activity -
Go to Tools > Send/Receive > Send/Receive Settings > Disable scheduled send/receive
Dec 30, 2008 | Microsoft Office Outlook 2007: Windows
Outlook 2007 - Emails sticking in outbox.
This generally relates to an issue with emails which include large attachments, and the settings for Outlook; however, it is typically seen with POP accounts rather than accounts associated with an Exchange server. This is a documented issue with Outlook 2003, and although it has not been documented as such with Outlook 2007, I have encountered several users with the same exact issue.
The root of this situation can be found primarily within the Outlook account settings. Basically, the time it takes to send the message with the attachment(s) is longer than the established setting for server timeout. Of course, the frequency of occurrence of this issue will vary depending on several factors: (1) the speed/bandwidth of the internet connection used for transmission; (2) the size of the message and attachment(s); (3) the server timeout setting established within Outlook for the email account being used; and (4) using file compression (zip) to decrease attachment size.
As you mention both Outlook 2007 and 2003, I am not certain if the issue is occurring in both instances, as it appears. I have not yet heard of this issue with Exchange involved, but I would imagine it is possible. Resolving the Exchange piece will take coordination with the administrator of the Exchange server, however, as the server would basically control the external communication piece.
On the individual PC being utilized, however, it is typical to find a server timeout set at 1 minute, and likewise, automatic send/receive set at 5 minutes. Though the automatic send/receive timing does not appear to be directly related to this problem, if the setting for the server timeout were to create a conflict with the automatic send/receive process, this could create further issues. Therefore, I recommend adjusting both settings in order to avoid any such conflict, in addition to correcting the primary problem regarding sending of email messages.
In Outlook 2003, the process for changing the server timeout is: Tools > E-mail Accounts > [select account] > Change > More Settings > Advanced. Then within the Advanced tab, there will be a slider below the title "Server Timeouts", which will lengthen the timeout as it "slides" to the right. The maximum is 10 minutes, and I have had users choose to set the time as high as possible, but generally 5 minutes should be sufficient. This setting is the primary contributor to the problem you are experiencing. In other words, the server is timing out in accordance with your settings, and those settings are causing a timeout before the message/attachment transmission can be completed. This is causing the cyclical treatment you are seeing, wherein the message transmission is not completed prior to the timeout of the server, therefore, it is beginning transmission again at the end of each timeout period (for example, every 1 minute). I would also caution at this point that, whatever the final choices may be, the ISP should be consulted to ensure that there is no standard or maximum, e.g., established for their service.
If you choose to change the Send/Receive ("S/R") Settings, this can be reached in two ways. (1) Tools > S/R > S/R Settings > Define S/R Groups; OR (2) Tools > Options > Mail Setup > S/R. Either path will bring you to a window titled "Send/Receive Groups" where you will see general settings for any groups set up within your Outlook application. For instance, it is typical to see a group titled "All Accounts" (which affects all email accounts included in the group), and often the checkboxes will be marked to include the group in S/R, to schedule automatic S/R every ** minutes (typically 5 minutes), and perhaps to perform an automatic S/R when exiting. It is recommended that any automatic S/R scheduled be longer than the server timeout as set above to avoid any potential conflict.
In implementing these changes, it is important to remember the involvement of the ISP and the general rules with which subscribers must comply; therefore, it would be prudent to verify that the ISP does not have any particular concerns with the values chosen for each of these functions. Additionally, depending on the typical size of the attachments included with your email messages, you may consider zipping the files prior to sending, which compresses the files and can result in file sizes reduced by perhaps 50%. Obviously, reducing file sizes would have a corresponding dramatic reduction on the amount of time required to transmit the message (and for the recipient to download same). Quickly, the easiest way to zip a file would be to right-click on the file in a "My Computer" or "Explorer" window, Send To, and choose Compressed/Zipped Folder. This will save your file with the same name within the same folder, but with a .zip extension, and file size will be dramatically lower.
Although the steps detailed above are directed toward Outlook 2003, the settings to be adjusted in Outlook 2007 are the same, just with a slightly altered path to reach each "end result". This is obviously a fairly complex issue, and I would welcome any further questions or requests for clarification if you need further assistance.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 28, 2008 | Microsoft Outlook 2003 for PC
947 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
