Tip & How-To about Ovens
Oven Problems Replacing the Igniter
If you have had the unfortunate experience of having the igniter on your gas oven go out at the worst possible time. Then you probably are also dreading the installation of the new igniter. Do not fear the replacement really is no that hard.
The first thing that you need to do is remove the racks from your oven.
Then look around at the back of your oven for the screws that hold the bottom pan down.
Remove those screws and remove the pan. Some need to slide back and then come up others will just pull up.
Remove the heat shield that is over the burner.
Remove the bottom drawer of your oven.
Now you should be able to see the igniter that sits on an angle by the burner tubes with a couple of wires coming out of it.
Removing the screws that hold the igniter is probably the most difficult part with some ovens. Sometimes it is easier to remove the whole bracket that holds the igniter and then remove and replace the igniter out of the oven.
The wires for the igniter will go to a Molex plug. Follow the wires and undo the plug. On many units it will be below the oven in the drawer opening at the top back. You will need to lay flat on the floor and reach back in to do this.
Once you have the old igniter out then you can carefully install the new one. Hopefully when you get it out of the box it will be in one piece yet. I had to get an igniter for an oven I worked on shipped three times before I got one that was not broken.
Any dropping or banging against anything will crack that igniter. BE CAREFUL!!
Check to make sure that you can feed the Molex plug and wires down through to the bottom before fastening the igniter.
Once the igniter is secured and the plug is connected, you can then replace the other parts in the reverse order that they came out.
This all sounds difficult, but really is not that hard. Even a first timer will have it done in less then a half an hour.
Ovens Logo
my oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
oven wont light
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils(This will be the next possible issue if the igniter is functional)
Sep 26, 2009 | Frigidaire Ovens
where is the reset button
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Jan 10, 2009 | Electrolux EOG7330WN Gas Double Oven
Stoves 900GRa spark ignition
i have a 900g stoves oven how do you change from auto to manual
Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
11,120 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
