Tip & How-To about Computers & Internet
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
Computers & Internet Logo
safe mode on a computer
When you start the PC, as soon as it hums up start hitting F8 button. The black window with a bunch of safe mode options will show up, select the one you need.
Aug 27, 2014 | Microsoft Windows XP Home Edition
HP Pavilion dv62020sa comes black screen how can i solved ?
HI there,
To understand this much better,could you please elaborate:
When it shows black screen,While booting up,after showing the Windows logo?
Which is the operating system?
However i will assume your operating system as windows 7.
I would suggest you to try the following steps:
Step 1:Disconnect all the external devices (printers, scanner, USB(universal serial bus) drives, etc...)Except mouse and the keyboard and then boot up.
If this corrects the issue then add the devices back one at a time until you discover the piece of hardware causing the issue. Then get any updated drivers\software for the device.
Step 2: Boot the computer in safe mode. To do this, follow the steps below:
Access the Advanced boot options menu by turning on your computer and pressing the F8 key continuously before Windows starts. On the advanced boot options menu select Safe Mode.
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
Enable clean boot in safe mode
Step 3: Put the computer in clean boot, to figure out if any third party software is hindering the process
Enable clean boot, see step 1 in the link below:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
If everything works fine after a clean boot, you can infer that some third party services are causing the problem.
Proceed with the remaining steps to pin-point out the third party service.
Note: After you figure out the problem causing program, you may have to update or install a higher version of the program, if you seldom use that software you can consider uninstalling
Important: - Remember to put the computer back to normal startup follow step 7 in the link.
Dec 24, 2010 | HP Computers & Internet
when i download a program it says my computer windows is in safe mode how do i remove it from safe mode
Follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Normal mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Mar 12, 2010 | Microsoft Windows XP Home Edition
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
Windows Restart
Hi, your best bet is to start XP in safe mode, or, if that does not work, do a repair after booting from your installation disk.
To use a Safe Boot option, follow these steps:
Feb 11, 2009 | Microsoft Windows XP Professional With...
342 people viewed this tip
David Payne
David Payne
