Tip & How-To about Office Equipment & Supplies
What to do if your ricoh 1022/1027/270/220 copier show SC452
To who had encounted this problem:
1. Don' t panic as the copier jammed temporarily
2. Switch off the copier
3. Open the lateral door,take out the fuser unit & replace the 2 unit termistor unit with the new unit [cost around us30]
4. Insert back the fuser unit then closed the laterl door
5. You have to reset the copier, below is the process:
6. Switch on the copier
7. Push button cancel[yellow] with button 1, 0,7 then follow
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
I have an HP Laser Jet 1320. The error light with the triangle and the explanation point is flashing. There is no paper jam. I have turned off the unit and plugged it back in. Can you please tell me what the error message is?
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
Sep 07, 2011 | HP LaserJet 1320 Printer
195 people viewed this tip
jasbo
jasbo
