Tip & How-To about Office Equipment & Supplies
What to do if your ricoh afficio 1022/1027/220/270 show sc542
First of all do not panic as the copier is in auto jammed mode.
Switch off the copier.Here the list you should do as the sc542 revealed your termistor in fuser unit is out of order.
1. Open the lateral door and take out the fuser unit
2. Below the fuser unit , you will see the 2 unit termistor with red plastic contact.
3 Replaced it both with the new one then reinsert the fuser unit in the copier back.
4.Closed the lateral door.
5.Switch on the copier,you should go into sp mode by push yellow[c] button follow by button 1,0,7 then push cancel button[red colour] for several seconds until the screen revealed you are in sp mode.
6. Switch off the copier for 1-2 minutes then switch on.
7. Wa la......it's working back as new
8.By doing this you will save several hundreds dollars by calling the techician isn't it.
Yours sincerely
SC542 IS APEARED ON SERVICE SCREEN
DEAR SABER, IT SHOW THE MACHINE TERMISTOR HAD TO BE REPLACED ,LATER after replacing it, you had to reset the machine in sp mode
Sep 09, 2013 | Ricoh Aficio SP C410DN Laser Printer
error sc542
this show the machine termistor had to be replaced.After you replaced it, you had to reset the machine by going into sp mode
Sep 05, 2013 | Ricoh Aficio 3025P Black and White Copier
nashuatec 2205 ATICIO problem SC 542
nashuatec 2205 equivalent to ricoh 1022/220 and the problem of sc542 means that you termistor is out of order. Don't panic,with little patient you could solve it.
Firstly,switch off the machine, then take out the fuser unit after you open the lateral door. Below the unit,you will see 2 termistor unit with red contact.Replaced it both with new unit.Reinsrt it the fuser unit back and closed the lateral door.
Switch on the copier, you must go in sp mode . First
push the yellow[c] button follow by button1,0,7 then
push red button[cancel] for several seconds until you in sp mode revealed by the screen.Switch off the copier for 1-2 minutes then switch it on,wa la it working back. It will cost you compare to calling the technician
Apr 15, 2010 | Ricoh 6513 Copier
jai un probleme avec un copieur Gesttner 3220 . A l ecran il me marque le code sc542 je demande de l aide SVP
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Apr 13, 2010 | Gestetner Copier
193 people viewed this tip
k24674
jasbo
jasbo
