Tip & How-To about Computers & Internet
Unknown error 13 or 14 ipod touch, iphone, itunes
Error 13 and 14: These errors are typically resolved by performing one of more of the steps listed below:
Perform USB isolation troubleshooting, including a different USB port directly on the computer.
Put a USB 2.0 hub between the device and the computer.
Try a different USB 30-pin dock connector cable.
Eliminate third-party security software conflicts by following iTunes for Windows: Troubleshooting security software.
There may be third-party software installed that modifies your default packet size in Windows by inserting a TcpWindowSize entry into your Registry. If your default packet size is set incorrectly it can cause this error. Contact the manufacturer of the software that installed the packet size modification for assistance.
Connect your computer directly to your Internet source, bypassing any routers, hubs, or switches. You may need to restart your computer and modem to get online.
Try to restore from another known-good computer and network.
Computers & Internet Logo
how to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
status light blinking red
please follow the steps given below to power cycle and reset the product.
Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product..
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
May 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
hp t65 error code
Step-1: Connect the All-in-One directly to power outlet
The surge protector may not supply sufficient power to the printer. To isolate the issue please remove the power plug of the printer from the surge protector and connect it to the wall jack directly.
Being a All-in-One Machine it needs full voltage to be supplied while initializing Surge protectors supply suppressed voltage to the printer which leads to unexpected issues in the printer
After performing the steps, please perform the steps below.
Step-2: Power Cycle the All-in-One
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality.
After performing the above steps if issue persists, please perform the below steps.
Step-3: Reset to Factory defaults
A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
  1. Unplug the power cord from the unit.
  2. Do the following according to your specific product:
    • HP Officejet G55 and G55xi series: Press and hold Minus ( - ) and 3 while plugging in the power cord.
    • HP Officejet G and K series:
    • Press and hold # and 3 while plugging in the power cord.
    • HP Officejet T series: Press and hold * and 8 while plugging in the power cord.
    • HP PSC 700 series: Press and hold Cancel and the Left Arrow while plugging in the power cord.
  3. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize. After RESET displays and the printer goes back to a ready state, the reset is complete.
  4. Try the print job again to see if this step resolved the issue.
Jan 29, 2009 | HP OfficeJet t65 All-In-One InkJet Printer
False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
341 people viewed this tip
David Payne
David Payne
