Tip & How-To about Computers & Internet
How to Put iPod into Disk Mode
Putting iPods with a Click Wheel into disk mode
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Computers & Internet Logo
froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
ipod won't mount, and show in itunes. Ipod 30GB Video will not load songs, pics, or movies. I have a macbook pro, itunes is updated. Ipod will not restore also. I also tried clearing the drive, ipod says could not unmount disk.
  5. Then attempt to restore.
Apr 12, 2010 | Apple iPod MA446LL/A MP3 Player
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
May 05, 2009 | Apple iPod nano 3rd Generation
My ipod isn't recharging or even turning on.
try putting the ipod into disc mode before connecting it to your computer to restore. Just in case you are unsure on how to put an ipod into disc mode, I have posted step by step instructions below. This is the only other option to restore the ipod and not need it repaired or replaced.
I hope it works for you :)
Apr 25, 2009 | Apple iPod nano 3rd Generation
When I connect my ipod nano 4th gen to my PC it won't appear in iTunes or in My Computer... What do I do to fix it?
These directions are taken from Apple.com.
Putting iPod into Disk Mode
http://docs.info.apple.com/article.html?artnum=93651
"1. Before manually placing the iPod into Disk Mode you should verify
that it has a charge, if not you need to either charge iPod before
continuing or connect it to power. You can either connect it to a
high-powered USB port, or plug the iPod Power Adapter into an
electrical outlet and connect iPod to the power adapter.
5. Disconnect iPod from the power adapter and connect it to your
disconnect"
If you are having difficulty putting an iPod model with a Click Wheel
into Disk Mode, set the iPod on a flat surface. Make sure that the
finger from the other hand to press the Play/Pause button."
This of course can also be used in reverse to switch from Hard Drive
mode back to iPod mode.
Oct 03, 2008 | Audio Players & Recorders
142 people viewed this tip
David Payne
David Payne
