Tip & How-To about Computers & Internet
Ipod not showing in itunes on a work computer with network drives
Important: Changing the iPod drive letter may not affect what letter the iPod uses on subsequent connections, so it is not the best long-term solution. If you are unable to change the drive letter of your mapped network drives, contact your system administrator.
Change the Drive Letter
Open the Control Panel.
**You Must be the compter admin to proceed ***
Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
Double click on Computer Management.
In the left column, click on Disk Management.
Locate the iPod and right click on it, then click Change Drive Letter and Paths.
Click the Change button.
Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
Click OK.
Click Yes on the confirmation dialog.
Close the Computer Management window.
Restart your computer.
Computers & Internet Logo
When connected with USB Cable in system its not working.
try changing the drive letters, also is this a fake Ipod?
Jul 11, 2009 | Apple iPod nano
The screen lights up da apple thingy but doesnt do anything else
Hi, This should work out:
Changing the drive letter of your network volume should resolve the issue. If you are unable to change the drive letter of the network volume because your programs depend on a specific drive letter, then you can use the following steps to change the drive letter of your iPod instead.
  1. Open the Control Panel.
  2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  3. Double click on Computer Management.
  4. In the left column, click on Disk Management.
  5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
  6. Click the Change button.
  7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
  8. Click OK.
  9. Click Yes on the confirmation dialog.
  10. Close the Computer Management window.
  11. Restart your computer.
Feb 02, 2009 | Apple iPod nano
ipod nano wont connect to pc
Try this out
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
then try to change the drive letter:
  8. Click OK.
Then try to restore the ipod to factory settings:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
This has to resove your issue
Jan 05, 2009 | Apple iPod nano
unable to reset
This issue is documented in Microsoft Knowledge Base document 297694, "New Drive or Mapped Network Drive Not
Available in Windows Explorer".
http://support.microsoft.com/default.aspx?scid=kb;en-us;297694
  8. Click OK.
Javier Gutierrez
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
99 people viewed this tip
David Payne
David Payne
