Tip & How-To about Computers & Internet
Enable or disable the firewall in windows 7
A firewall is a software or hardware base solution to filter the incoming and outgoing traffic of your computer or network. All the entering or leaving traffic from your computer pass through the firewall, which inspect the all types of traffic and either allow or deny the traffic depending upon the firewall settings. Microsoft includes the built-in firewall feature in all latest windows operating systems like windows XP, Vista and now in windows 7.
Follow the given steps to configure built-in firewall in windows 7:To use this feature, you will need to be logged into your computer with administrative rights.
First click on Start button and then click on Control Panel option. Now in Control Panel click on "System and Security" link to go next.
On next page, you can see the firewall link "Windows Firewall", Click on this link to configure the firewall.
There are many options on the left side panel of this page regarding firewall configurations under "Allow a program or feature through Windows Firewall", For example:
- Change notification settings
- Turn Windows Firewall on or off
- Restore defaults
- Advanced settings
On the right side panel, you can see the two types of link for firewall settings, For example:
- Home or Work (Private) networks
- Public networks
Now in left side panel, click on Change notification settings to customize the firewall settings.
By default windows firewall is on for both private and public network, here you can turn off the default firewall policies.
To allow the default or recommended settings either click on the Use recommended settings button on the right pane or click on the Restore default link on the left side panel.
Here click on the Restore default button and a restore defaults confirmation message will be opened, Click on Yes button.
But if you are a expert user then you can use the Advance Settings link on left side panel to configure the advance firewall settings for inbound and outbound traffic according to your need.
Click on the Inbound Rules link in the left side panel. You can see here a list of all Inbound Rules is displayed. On clicking an enabled rule, a list of actions is shown in the Actions Pane. Click on Disable Rule to disable the selected rule. You can also Cut, Copy and Delete the rule.
Computers & Internet Logo
error 0x8007064c when installing windows live messenger on windows 7.
How to enable Windows Firewall when you receive an error code 0x80070643 or 0x800706d9 during Windows Live Essentials installation
Symptom:
Users are reporting installation issues when installing Windows Live Essentials.
You might receive one of the following error codes during the installation process: 0x800706d9, 0x80070643
Cause:
When Windows Firewall is disabled, installation of Windows Live Essentials could fail in some cases, because some Windows Live Essentials components require Windows Firewall to be enabled in order to install successfully.
Background information:
Windows Firewall is a software based solution to filter incoming and outgoing traffic of your computer or network. All traffic to and from your computer pass through Windows Firewall, which inspect all types of traffic and either allow or deny traffic depending upon the firewall settings. Microsoft includes the built-in firewall feature in all latest Windows operating systems like Windows XP, Windows Vista and Windows 7
Resolution Steps:
To enable Windows Firewall in Windows Vista/7 please follow the steps:
Note: To use this feature, you will need to be logged into your computer with administration rights.
1. Click on Start button and then click on Control Panel option.
2. In Control Panel click on System and Security link to go next.
3. Click on the link Windows Firewall
4. On left side panel, click on Turn Windows Firewall on or off
5. Select Turn on Windows Firewall for all (Domain, Home and Public network)
Jun 11, 2011 | Microsoft Computers & Internet
Router Firewall
Not entirely. Hardware firewalls (such as the one in your router) will block incoming connection attempts based on the port they're using, the protocol, and a number of other factors (varied between firewall brands). Some are designed to block only popular attacks (DoS, PoD, crackers on port 80, Telnet connect attempts, etc...) while others will block a larger variety of attacks.
Anyways, software firewalls will block almost all incoming Internet traffic (except for the ones defined in the exceptions) along with almost all outgoing Internet traffic. The only way I find this to be useful is if you're trying to keep some private information private, or if you use that computer to determine if some software is trying to phone home (web beacon, trojan, dialer, etc...).
I really don't see the need for Software firewalls unless you're a hard-core web-surfer and don't care what you click on. If you do like the extra security, perhaps one of the better software firewalls is made by ESET.
I prefer ESET to Symantec's Personal Firewall because Symantec's Firewall on one of my older systems was hijacked by a virus a few years back which allowed the virus unprecedented access to the root of my Operating System. The virus gutted the computer without any alerts from Norton CE or the Firewall.
Anyways, I hope this was the answer you were looking for. If not, please feel free to respond with more details on what you were truly asking. All the best. ;-)
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
messenmer access
  • A firewall is a hardware or software solution to enforce security policies. In the physical security analogy, a firewall is equivalent to a door ...
  • A firewall is a system that secures a network, shielding it from access by unauthorized users. Firewalls can be implemented in software, hardware or a combination of both. In addition to preventing unrestricted access into a network, a firewall can also restrict data from flowing out of
  • A system or combination of systems that enforces a boundary between two or more networks.
  • A barrier in a network that will only pass packets authorized to reach the other side.
  • A firewall prevents unauthorised access to or from a private network. A firewall can be installed either via hardware or software or a combination of both and it is designed to prevent and filter unauthorised access via the internet to a private network.
  • A firewall is a safeguard utilized by many Local Area Networks (LANs) or Wide Area Networks (WANs) to protect the network from unauthorized access from the outside. They are basically gates that verify the users before they leave or enter the network by way of a User ID, Password or IP address.
  • A security barrier placed between an organization's internal computer network - either its IS system or intranet - and the Internet. It keeps your information in, and unwanted people out. It consists of one or more routers, which accept, reject, or edit transmitted information and requests.
  • A method of protecting one network from another network. A firewall blocks unwanted access to the protected network while giving the protected network access to networks outside of the firewall. ...
  • A form of Internet security that typically stands between a private network and the external Internet (although internal firewalls are also now increasingly common) and is designed to prevent unwanted traffic from passing.
  • A combination hardware and software buffer that many companies or organizations have in place between their internal networks and the Internet. A firewall allows only specific kinds of messages from the Internet to flow in and out of the internal network. ...
  • A method for keeping a network secure from intruders. It can be a single router that filters out unwanted packets or may comprise a combination of routers and servers each performing some type of firewall processing. ...
  • Specialized software and/or hardware designed to prohibit unauthorized access to information on a computer network.
  • Any of a number of security schemes that prevent unauthorized users from gaining access to a computer network or that monitor transfers of information to and from the network.
  • a security device that protects a computer network by isolating it from the rest of the Internet and by only permitting specific traffic to pass in and out.
  • Jul 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
    205 people viewed this tip
    David Payne
    David Payne
