Tip & How-To about Computers & Internet
How to fix internet issue: Page cannot be displayed.
These steps would help you to fix the wired internet connection problem like desktop connected to modem. However, if you have a laptop and not connected to wireless, then connect a cable directly from the router to the laptop and follow the steps given below:
1.Launch internet explorer. If you see a message, page cannot be displayed, please follow the steps given below:
A.Check if the proxies are enabled or not.Click start, launch Internet explorer,Click Tools, click Internet Options.Click Connections, click LAN settings.Under Proxy server, uncheck both of the check boxes mentioned below:
i)Use a proxy server for your LAN
ii)Bypass proxy server for local addresses.Now, click OK, then click Apply and OK.Close internet explorer and launch it again.
2.If you are still not able to go online, reset internet explorer as under:Click start, lauch Internet explorer,Click Tools, click Internet Options.Click Advanced, click Reset, click Reset again.Now, click Close, apply and OK.
3. If you are still not able to go online, check the IP address.Click Start, click Run and type in "cmd" and hit enter.(In Widow Vista and Window 7, Click Start, and type in the 'Start Search' box, 'cmd', Now, right-click 'cmd' at the top and click 'Run as administrator'.)Now, on the black screen, type in 'ipconfig'. You will see IP address under "Ethernet Adaptor Local Area Connection". (IPV4 in case Window Vista and Window 7).
A. If the IP address is starting with 169.,follow the steps given below, else follow the steps under B.
i. Check if the ethernet cable is connected properly form the modem to the computer.(if you have a router, then from the modem to router and router to computer). Disconnect these cables once, shut down the computer, modem, router. Connect all of these cables back and restart, first modem, then router and at last computer. Check if you are able to go online or not, if not follow the next step.
ii. On the black screen, type in 'ipconfig /release' and hit 'Enter' on the keyboard. Now, type in 'ipconfig /renew' and hit 'Enter'. Now, check the IP address under "Ethernet Adapter Local Area Connection". If IP is again 169.., follow the next step. Else, minimize the black screen and launch internet explorer to check if you rae able to go online.iii. If you are still not able to go online, maximize the black screen and type in ipconfig /flushdns and hit Enter.iv. Now, on the black screen, type in 'ipconfig', if you still see an IP address starting from 169.., uninstall the security like Norton, McAfee etc. Restart your computer and check if you are able to go onine or not.
B. If IP address is starting from 192.. or 10.. or anyone except 169., please follow these steps:
i. On the black screen type in, ping www.google.com.
ii. If it is pinging sucessfully, (you see four lines reply from, reply from..) launch intenet explorer. Otherwise, if you see, "ping request could not find the host.", go to the next step.
iii.Check if the ethernet cable is connected properly form the modem to the computer.(if you have a router, then from the modem to router and router to computer). Disconnect these cables once, shut down the computer, modem, router. Connect all of these cables back and restart, first modem, then router and at last computer. Check if able to go online or not, if not follow the next step.
iv. On the black screen, type in 'ipconfig /release' and hit 'Enter' on the keyboard. Now, type in 'ipconfig /renew' and hit 'Enter'. If you are not online go to the next step.
v.Click start, right click, My Computer, click Manage, click Contiue(if you see any), Click Device Manager on the left-hand side. Now, on the right-hand side, click + sign in front of the Network Adaptor. Under Network Adapter, right click on the adaptor and click Uninstall and click OK. Now, restart the computer. If you are not online go to the next step.
vi.Uninstall the security like Norton, Mcafee etc., restart your computer and check if you are able to go onine or not.
vii.Clean-boot the computer, remove the startup items as under:
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner.
In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner.
Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.
Now, scroll up to the top and click Computer, right-click it and click Export and save it as file name say backup on the desktop.In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolderRight click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.Restart your computer.
viii.If you are not able go online, restart the computer in the safe mode with networking as under:
As soon as you restart the computer start tapping F8 key and choose, safe mode with networking and hit Enter.Scan the computer with good anti-malware, anti-spyware, antivirus.
http://malwarebytes.org/
http://superantispyware.com/
If you are not online, go to the next step.
ix.Winsock registry keys might be damaged or corrupted. Please follow these steps to fix them.
1.If you have window xp with service pack 2:Click start, click run, type in cmd. Hit enter. On the black screen, type in "netsh winsock reset".Now, restart the computer.
2. If you have window xp without service pack 2:
In this case, you have to delete the corrupted registry keys, and then reinstall the TCP/IP protocol.Here are the steps:Delete the corrupted registry:Click Start, click Run.Type regedit, and then click OK.In Registry Editor, locate the following keys, right-click each key, and then click Delete: HKEY_LOCAL_MACHINESystemCurrentControlSetServicesWinsockHKEY_LOCAL_MACHINESystemCurrentControlSetServicesWinsock2When you are prompted to confirm the deletion, click Yes.
Install TCP/IP:
Click Start, click Run, type in ncpa.cpl and hit Enter.(In Widow Vista and Window 7,Click Start, and type in the 'Start Search' box).
Right-click the network connection(Local Area Connection), and then click Properties.Click Install.Click Protocol, click Add.Click 'Have Disk'.
Type C:Windowsinf, and then click OK.On the list of available protocols, click Internet Protocol (TCP/IP), click OK.
If Internet Protocol (TCP/IP) does not appear, follow these steps:Click Start, and then click Search.In the Search Companion pane, click More advanced options.Click to select the following three check boxes:Search system folders.
Search hidden files and folders and Search subfolders.In the All or part of the file name box, type nettcpip.inf, and then click Search.In the results pane, right-click Nettcpip.inf, and then click Install.Restart the computer.
3. If you have Window Vista or Window 7:Click Start, and type in the 'Start Search' box, 'cmd', Now, right-click 'cmd' at the top and click 'Run as administrator'.Type "netsh winsock reset" on the black screen then press ENTER.Restart the computer.
If all of these steps do not fix the internet issue, please repair or reinstall your operating system.
Computers & Internet Logo
My laptop can't find a connection to m router.
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
Dec 29, 2009 | Belkin (F6D3230-4) Router (F6D32304)
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
wireless laptop
You may need to temporarily wire the laptop to the router.
who is your internet service provider and what is the brand or model no. of your modem?
What is the operating system of your laptop?
I can give you the steps on how you can configure the router for internet and after that i can give you the steps on how to setup the wireless on the router.
Aug 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
connecting 2 pcs with a single pc modem
if you have a landcard in your laptop you can use a wired connection to your laptop.. be sure you have a UTP cable to get through on it.
Jun 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
590 people viewed this tip
David Payne
David Payne
