Tip & How-To about Microsoft Windows Vista Ultimate Edition
Registry Hacks
Menu Speed
When XP first appeared, there was a lot of conversation about the new interface, both good andad. In spite of the initial complaints, most users stick with the default settings rather than reverting to the Classic interface found in previous Windows versions. But you may want to change the delay you notice when you click on the Start Menu. I see no reason for there to be any delay when I click on the Start Menu. Effects are pretty, but I wouldn't click on it if I didn't have business inside, so let's get it open and get moving. The default speed can be adjusted with a quick Registry hack.
Go to the Registry key HKEY_CURRENT_USER\Control Panel\Desktop\MenuShowDelay. The default value is 400. Set it to 0 to remove the delay completely, but if you do that it will be nearly impossible to move the mouse fast enough not to activate All Programs if you mouse over it en route to your final selection. Pick a number that suits your style, make the change, then test it until you find a good compromise between speed and usability.
Place Windows Kernel into RAM
It's a given that anything that runs in RAM will be faster than an item that has to access the hard drive and virtual memory. Rather than have the kernel that is the foundation of XP using the slower Paging Executive functions, use this hack to create and set the DisablePagingExecutive DWORD to a value of 1.
Edit the Registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ Session Manager\Memory Management\DisablePagingExecutive to 1 to disable paging and have the kernel run in RAM (set the value to 0 to undo this hack). Exit the Registry and reboot. Perform this hack only if the system has 256 MB or more of installed RAM!
Disable 8.3 Name Creation in NTFS
Files that use the 8.3 naming convention can degrade NTFS drive performance. Unless you have a good reason for keeping the 8.3 naming convention intact (such as if you're using 16-bit programs), a performance gain can be achieved by disabling it:
Set the Registry DWORD key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ FileSystem\NtfsDisable8dot3NameCreation to 1. Exit the Registry and reboot.
Whenever you surf the Web, you leave yourself open to being snooped upon by web sites. They can track your online travels, know what operating system and browser you're running, find out your machine name, peer into your clipboard, uncover the last sites you've visited, examine your history list, delve into your cache, examine your IP address and use that to learn basic information about you such as your geographic location, and more. To a great extent, your Internet life is an open book when you visit.
Don't believe me? Head to http://www.anonymizer.com/snoop/test_ip.shtml. This page, run by the Anonymizer.com web service, tells you what your IP address and machine name are. And that's just a start. Click on the links on the left side, such as "Exposed Clipboard" and "Geographical Location." You'll see just a small sampling of what web sites can learn about you.
Much of the reason why web sites can find out this information about you is due to the trusting nature of the Internet's infrastructure and is inherent in the open client/server relationship between your web browser and the servers on the sites you visit. But a lot of it also has to do with the ability to match up information from your PC to information in publicly available databases—for example, databases that have information about IP addresses.
The best way to make sure web sites can't gather personal information about you and your computer is to surf anonymously; use an anonymous proxy server to sit between you and the web sites you visit. When you use an anonymous proxy server, your browser doesn't contact a web site directly. Instead, it tells a proxy server which web site you want to visit. The proxy server then contacts the web site, and when you get the web site's page you don't get it directly from the site. Instead, it's delivered to you by the proxy server. In that way, your browser never directly contacts the web server whose site you want to view. The web site sees the IP address of the proxy server, not your PC's IP address. It can't read your cookies, see your history list, or examine your clipboard and cache, because your PC is never in direct contact with it. You're able to surf anonymously, without a trace.
There are two primary ways to use anonymous proxy servers. You can run client software on your PC, which does the work of contacting the server for you, or you can instead visit a web site, which then does the work of contacting the server.
Microsoft Windows Vista Ultimate Edition Logo
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer cannot display content. when i try entering the adress again, I get directed to google searching for 192.168.1.254 I have no modem password protected, no proxy in use for its on auto, the modem is brand new pluged in the right voltage, all the wired and wireless conections are good. I need to get on the configuration page to set up a wireless password and to configure the UPnP settings, putting in mined I only configured it the basic info that gets me online.
Please try one of the following option:
Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
484 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
