Tip & How-To about Watches
Changing a watch battery.
If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
Watches Logo
how to take the back off of a mossimo watch
take to a jeweler with a watchmaker, or at least to a jewelry store that works on watches. You may be able to get it off, but you will never be able to get it back on!
Jul 04, 2014 | Bulova Watch
my seiko 5 automatic runs to quick
Balance spring in your watch is sticking together and causing the watch to run fast. It can happen when watch gets magnetized or there is some oily residue left on balance spring. To fix this you will have to show your watch to the watchmaker, because this is very specialized job to do and the balance spring is so delicate part, it can be damaged by simple touch.
Feb 28, 2011 | Seiko Watch SNXJ89K1
I want to know how to open my guy laroche watch it's pretty expensive. I think itt is a snap on back but it doesnt have a little lip or nething on the back i tried using a knife but there is no space to fit the knife in between the gaps.
If there is no lip, then yes, it can be very very tricky. And since it is an expensive watch, I am sure you dont want to damage it. I would highly recommend a qualified watchmaker to do it. SOmetimes watches that are hard to get back off, its hard to get them back on too.
Best wishes.
Aug 19, 2010 | Watches
how do you open a DKNY 3423 watch?
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 11, 2010 | Bulova Watch
How do you change the battery on the T-Touch Expert watch?
I would not recommend changing this battery yourself unless you have the proper tools to close the case! If its a screw back then you will need a case wrench to close it otherwise you will scratch the case and case back! Plus it has a touch sensitive crystal! Screw that up and you will have to send it back to Tissot to have it repaired! That will NOT be covered by the warranty!
Jan 09, 2010 | Watches
704 people viewed this tip
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
