Tip & How-To about Garden
Belt replacment
If you find yourself needing to replace a worn belt from the mower deck or from the drive pully's, draw a diagram on a piece of paper or cardboard how the belts are run include all pully's and don't forget which direction it is going so it should be easier to reinstall the belts...good luck
Garden Logo
I need a diagram to remove a drive belt
You dont need any diagrams to change a belt just turn the mower up on 1 side and see where the belt goes and if you want to draw your own diagram and keep it safe But then you will find a idler drive pully on all mowers and that is either spring loaded or a nut and bolt holds it tight,,, and that could be the one that drives when you put the lever in CUT but have a good look and its easy to do..
Let me know how you go Ron
Oct 04, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Blade belt pullys, need diagram, picture.
Need to know what Model # you have?
Try going to www.precisionope.com and put your model number in there to see if it can give you what you need.
Oct 02, 2009 | Garden
I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN MOWER TO PUT THE BELTS ON THE DECK
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Jul 11, 2009 | Garden
i need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
161 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
