Tip & How-To about Office Equipment & Supplies
Removing a paper jam from an older DeskJet printer
Firts remove the back panel by turning the large knowb in the center. Then if more than 2 pages are stuck inside "gently" pull on all the sheets except the top and bottom ones. They should pull out with moderate resistance. Once thos sheets are ou do the same thing with the remaining two sheets.
NOTE: when a printer is powered on with paper already in the paper path it will usually try to eject them by turning its rollers.
NOTE: some older HP DeskJets when you press the paper feed button (with paper already in printer) it will move the paper in one direction and when you press again it will move the paper in the opposite direction.
doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
paper is jammed
Apr 14, 2010 | HP DeskJet 845c Printer
headlight assembly
Pull upward on black cover above headlamp assy. (marked pull here for headlamp service) you will then see on the front side a large bolt above the lamp assembly that holds it to the front of the car. it is a 10MM socket you will then need to remove a similar bolt on the top and bottom on the center front of the car where the assembly bolts up to the sheet metal. on the corner near the cornering lamp is a star shaped head bolt. (looks like star of david) you will need another small metric socket to remove this. this will free up the cornering lamp from the headlamp assembly. gently pull forward and away from headlamp assembly. remove both light pig tails by gently twisting on pigtails. you will then see 2 nuts which are also 10mm remove these and gently pull forward on entire headlamp assembly. you will need needle nose pliers to compress the head of plastic retaining tabs on headlight and signal light pig tails where they are held into the headlamp assembly. gently twist hi-low beam sockets free of the headlamp assembly then do like wise with the signal lamps. to install reverse procedure as above. note: the side with the cornering lamp has a tab that must fit back into tab-hole in front sheet metal of the front fender
Dec 15, 2008 | 2001 Cadillac DeVille
Very Back Door Handle Stuck Up
Remove the inside door panel by gently prying with a large regular screwdriver or pry bar. There are the usual plastic "rivets" that hold this into place. Inside, you will see a plastic moisture barrier. Gently peel this back to reveal the cheesiest door handle assembly in the known universe. The link for the handle is fragile and barely several hair widths in diameter. You'll want to lubricate this generously and after letting it soak, rock it back and forth to work it in. These are prone to rust so be GENTLE. Also, if you ever need to replace the rear license plate lights, this is the way to do it, in addition to removing several phillips screws that hold the handle into place. Not an easy task but with a little forebearance you can manage it well. Just snap everything back into place when you're done and call it a day. Good luck!
Sep 10, 2008 | 2000 Chevrolet Tracker
160 people viewed this tip
jasbo
jasbo
