Tip & How-To about Computers & Internet
How to fix an Error message 3001, -42110, or 5103 when downloading movie rental for windows Xp
Open My Computer from the desktop or Start Menu.
From the Tools menu, choose Folder Options.
Click View tab.
In the "Advanced settings" pane under "Hidden files and folders," make sure that the "Show hidden files and folders" option is selected.
Click OK.
Navigate to the following location by either typing it into the address bar, copying and pasting it into the address bar, or clicking through the folder hierarchy listed:
C:\Documents and Settings\All Users\Application Data\Apple Computer\iTunes\
Right-click the SC Info folder shown and on the shortcut menu, choose Delete.
Restart the computer.
Open iTunes and choose Store > Check for available downloads.
After your rental finishes downloading, choose Store > Authorize.
Enter your account name and password, then click the Authorize button.
Computers & Internet Logo
DEP keeps shuttting down itunes
From the Start menu, click Open.
In the Organize menu, click Folder and Search Options.
Click the View tab.
In the "Advanced settings" pane under "Hidden files and folders" make sure that the "Show hidden files and folders" option is selected and that "Hide extensions for known filetypes" is unchecked.
Click OK.
Now open your C:\Windows\System32\ directory.
(In a standard QuickTime installation on a 32-bit system you should see just two files ... QuickTime.qts and QuickTimeVR.qtx ... and no QuickTime folders whatsoever.)
Drag the entire QuickTime folder into your desktop. (Leave the two other files in place.)
Now try launching iTunes again.
Mar 28, 2011 | Apple iTunes
how to install back the recycle bin icon how to erase download files in recycle bin
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box.
  4. Click Yes when you receive the warning message, and then click OK to close the Folder Options dialog box.
  5. Click Folders on the toolbar.
    Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons.
  6. In the left navigation pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop.
  7. On the Tools menu, click Folder Options.
  8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.
Feb 26, 2010 | Computers & Internet
Unable to network
Are they running Windows XP? If so enable file sharing...
  1. Open My Computer from the Start Menu or Windows XP Desktop. A new My Computer window will appear.
  2. Open the Tools menu and choose the "Folder Options..." option from this menu. A new Folder Options window will appear.
  3. Click on the View tab and locate the "Use Simple File Sharing (Recommended)" checkbox in the list of Advanced Settings.
  4. To enable Simple File Sharing, ensure this checkbox is checked. To disable Simple File Sharing, ensure this checkbox is not checked. Click inside the checkbox to alternately enable and disable the option.
  5. Click OK to close the Folder Options window. The settings for Simple File Sharing are now updated; no computer reboot is required.
Jul 07, 2009 | Netopia Computers & Internet
i deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Aug 20, 2008 | Gateway Computers & Internet
recycle bin
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
790 people viewed this tip
David Payne
David Payne
